VW Hybrid Battery Packs
Revision as of 11:26, 12 February 2021 by Bigpie (talk | contribs) (→‎Golf GTE)
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
Golf GTE
Main terminal
Main terminal
BMS
Battery Modules
Passat GTE
Module Weight
BMS Board
Golf GTE
Module Label
Module Label
Lower Mounting bracket
Higher mounting bracket
Cooling
Original Pipework Connector
Contactors/Pre-Charge
Passat GTE
The Control box contains
  • PEC 300A 450VDC fuse
  • 1 x Contactor Control Board
Contactor Box
HV Contactor
Pre Charge Relay
INSERT
Resistor Pic
Fuse
Shunt
Control Board
Golf GTE
The control box contains a
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Pre-charge relay
Pre-charge relay
Contactor
Contactor
1 Connects to battery case Black Ring terminal on the end, maybe for isolation test?
2 Gnd Black
3 N/C
5 CAN L Black
6-9 N/C
10 Red
11 Red
12 White
13 N/C
14 White
15-19 N/C
21 Contactor switched gnd Black
22 Contactor switched gnd Black
23 12v for precharge relay Yellow Isolated from 12v supply
24 12v for contactor Blue Isolated from 12v supply
25 12v for contactor Red Isolated from 12v supply
26 N/C
Using Multiple Packs
