External links
Forum discussion
> CAN logs
> STM32 VCU software
> I3 LIM CAN dbc1
BMW I3 HV components
LIM versions
LIM versions
SN IEC 61851
J1772 (AC)
61 35 9 346 827 x x BMW i3
61 35 9 346 820 x x BMW i3
Mini cooper SE
now
The LIM's are available new from BMW spare parts suppliers for € 240 but there might be some programming/codeing necessary before the unit behaves like the ones used during development of the solution.
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1 / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector Hirschmann 805-587-545
Audi 7M0 973 119
TE 1-967616-1
X Replacement Pins 5-962885-1
X Rubber Seal 1-967067-1
LIM pinout
1B Pinout:
Pin # Function Description
1B-1 -
1B-2 -
1B-3 LED_M Lighting Charge Socket? (Not necessary)
1B-4 LOCK_MOT+ Charge Inlet Lock Motor
1B-5 LOCK_MOT- Charge Inlet Lock Motor
1B-6 CAN_H Powertrain CAN
1B-7 CAN_L Powertrain CAN
1B-9 VCC Constant Power +12V
1B-10 GND Ground
1B-11 -
1B-12 -
1B-13 -
1B-14 - Internally connected to GND
1B-16 LOCK_FB Charge Inlet Lock Feedback (1k unlocked, 11k locked)
2B Pinout:
2B-1 CP Pilot (Charge Inlet)
2B-2 PP Proxy (Charge Inlet)
2B-5 GND Ground (Charge Inlet)
3B Pinout:
- N/A (for CHAdeMO only)
4B Pinout:
4B-5 U_HV_DC Charge Inlet DC Voltage (current input 3-20mA?)
4B-10 COV_MOT- Charge Inlet Cover Motor (Not necessary)
4B-11 COV_MOT+ Charge Inlet Cover Motor (Not necessary)
4B-12 COV_FB Charge Inlet Cover Feedback (connect to GND to simulate open cover)
Wiring Diagram
Required CAN messages
ID Function interval Notes
0x112 BMS msg. 10ms
0x1A1 Vehicle speed 20ms
0x3E9 Main LIM control 200ms
0x431 Battery info 200ms needed but does not control anything
0x03C Vehicle status 200ms
0x2A0 Central locking 200ms
0x397 OBD 200ms
0x3F9 Engine info 200ms Rex?
0x3A0 Vehicle condition 200ms
0x330 Range info 200ms
0x432 BMS SoC 200ms
0x51A Network management 200ms
0x540 Network management 2 200ms
0x512 Network management edme 200ms
0x560 Network management kombi 200ms
0x510 Network management zgw 200ms
0x328 Counter 1s
0x3E8 OBD reset 1s
0x2FA Lim DC charge command 3. 1s
0x12F Wake up 100ms
0x2FC Charge flap control 100ms
0x2F1 Lim DC charge command 2. 100ms
LIM peripheral boards
isolated DC Voltage sense board by muehlpower
Large fast charging contactor control board
The LIM measures the current draw of the pos and neg fast charging contactors which makes it a bit harder to use large Gigavac contactors.
The easiest option is to place a small relais and a +/-20 watt 15 ohms (or slightly bigger) wire wound resistor in parallel to simulate the original contactor coil and drive a large Gigavac contactor with internal PWM economizer or dual coil.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Duosida inlet lock feedback
The i3 uses a quite expensive Phoenix CCS inlet and it would be nice to be able to use the cheaper Duosida CCS inlets.
The charge inlet lock should work with the Duosida lock as well but the feedback (1k unlocked, 11k locked) is a bit different which requires some additional resistors.
CCS inlet lock
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
RGB LED
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
Observations
LIM board components
components
