Nissan leaf motor couplers and adapter plates
Revision as of 22:29, 9 October 2021 by Bratitude (talk | contribs)
adapter plates
cnc machined aluminum adapter plate for em57 motor
motor coupler and adapter plate on a em57 motor
adapter plate for the em57 motor cad files:
https://github.com/angusjo/leaf-splines/blob/master/adapterplate.SLDPRT
the adapter plate is designed for the em57 motor, and utilizes all the locating dowls.
the design uses a 1in thick piece of aluminum, milled down slightly for ensure a square and accurate fit. there is a bearing boar in the design, which utilizes the ---- angular contact bearing for alternative setups where there may be axial loads on the motor shaft. the bearings in the leaf motor are not designed for these types of forces, and will fail, so the need for a support bearing is paramount.
a support bearing isnt required if the motor is just directly mated to another gearbox.
*refer to the drawing of the adapter plate when machining, and not the cad file, to ensure the machine is following accurate data
motor couplers
motor shaft coupler for gen1/2/3 leaf (em61 and em57 motors) are for sale via brat industries:
contact him via email:
angusjohnson@protonmail.com
motor coupler drawing
https://openinverter.org/forum/viewtopic.php?f=12&t=569
