Nissan Leaf Motors
The Nissan EM motor is an electrical motor manufactured by Nissan Motors. It is an 3-phase AC synchronous power electric motor, that uses interior neodymium permanent magnets
motor couplers and adapter plates designs can be found here
1st generation: em61
used in the first generation nissan leaf, is a stand alone ipsm motor with a theoretical peak power output of a 250kw+.
regarded as nissans "r&d" motor, being the presents of stronger rare earth magents and design. resulting in a slightly higher torque output effeicny than the gen2 em57 motor.
In the stock OEM leaf, the motor was battery and inverter limited to 80kw and made 280Nm of peak torque.
The EM61 made its debut in 2010. It was used only in the first generation Nissan Leaf (ZE0 2010-2012).
2nd generation: em57
The em57 utilizes a stacking architecture for the power electrons, compared to the isolated nature of the em61 motor.
Nissan has continued to use the em57 motor threw multiple generation of vehicles, resulting in mechanically plug and play OEM inverter upgrades.
inverters currently compatible with the em57 motor:
- gen 2 leaf 80kw inverter
- gen 3 leaf 110kw inverter
- gen 3 leaf 160kw inverter
EM47
The EM47 motor released in 2020 with the refreshed Nissan Note. It is only used in Nissan's e-POWER lineup. It features a 40% size reduction and 30% weight reduction
