Toyota P310 CVT
Jump to navigation
Jump to search
Description
The P310 is considered a third generation e-CVT.
Model Code
Applications
- Toyota Highlander (2006-2010)
- Lexus RX 400h (2005-?)
Specifications
MG1
Rated Voltage: ?
Max Output: ?
MAX RPM: ?
Power split device planetary gearset ratio is ?.
MG2
Rated Voltage: ?
Max Output Power: ?
Max Output Torque: ?
Max RPM: ?
Motor is sent through "motor speed reduction" gearset with a ratio of ?:1.
Final Drive Ratio
MG2 to final drive ratio: ??:1
Ring to pinion gear ratio: ??:1
Oil Pump
Fluid Capacity
??L of Toyota WS fluid.
Weight
? lbs
