Toyota P310 CVT
Revision as of 16:24, 23 December 2021 by Lsh3rd (talk | contribs) (Updated models... broke out all P3xx series - consider separate wikis depending on how many differences are discovered.)
Description
The P310 is considered a third generation e-CVT with two planetary gearsets, one for "motor speed reduction" which reduces the speed of the MG1 rotor. Derivatives include P311, P312, P313, and P314 (should these get their own pages?).
Model Code
Applications
P310
  • Toyota Highlander (2006-2010)
  • Toyota Kluger Hybrid
  • Toyota Harrier Hybrid
  • Lexus RX 400h (2005-?)
P311
  • Toyota Camry Hybrid
  • Lexus HS250h
P312
  • Nissan Altima Hybrid
P313
  • Lexus RX 450h
P314
  • Lexus NX 300h
  • Toyota RAV4 Hybrid
Specifications
MG1
Rated Voltage: ?
Max Output: ?
MAX RPM: ?
Power split device planetary gearset ratio is ?.
MG2
Rated Voltage: ?
Max Output Power: ?
Max Output Torque: ?
Max RPM: ?
Motor is sent through "motor speed reduction" gearset with a ratio of ?:1.
Final Drive Ratio
MG2 to final drive ratio: ??:1
Ring to pinion gear ratio: ??:1
Oil Pump
Fluid Capacity
??L of Toyota WS fluid.
Weight
? lbs
MG1 Stator
MG2 Stator
MG1 Resolver
MG2 Resolver
Park Shift Linkage Motor
Reference
