Tesla Model S/X Small Drive Unit ("SDU")
Revision as of 00:12, 20 February 2022 by Jason arnold (talk | contribs)
The Tesla SDU is used on Model S/X in both rear and front depending on the model.
Front SDU Connectors
Purchase in openinverter shop
Setup FAQ
Drop-in control board
Tesla SDU drop-in board
Wiring connections
Application Info
