Toyota Prius Gen2 Board
Revision as of 18:27, 13 December 2019 by MattsAwesomeStuff (talk | contribs)
Prius Board v1
The Toyota Prius Gen2 Board is an open source project to repurpose 2004-2009 Toyota Prius inverters for DIY EV use. It consists of a circuit board and programming that replaces the Prius' original ECU.
Prius Inverter
Prius Gen 2 Inverter Montage
  • Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
  • 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
How To Use
The control board utilizes the Blue Pill (link?) microcontroller, and takes advantage of the OpenInverter.org software (link?) for control.
Pin Header Summary
Control Board Description:
Pin # Designation Description
TB1-1 12v-in (Do I supply this or is this created by the HV Battery connecting to the inverter, which then creates 12v from its DC-DC converter?)
TB1-2 GND (All GNDs in common? Chassis GND or HV battery Neg?)
TB1-3 5v VCC (Looks like this is created by this board, from the 12v in. Does it wire to the inverter?)
TB1-4 Throttle In (Added by me with a pedal? If so what's expected? Also connected to inverter or not?)
TB1-5 Regen In (Ditto with throttle same questions)
TB1-6 GND
TB1-7 Brake In (Ditto with throttle)
TB1-8 Start In (Ditto with throttle)
TB1-9 For In (Forward input? Just a signal? Ditto with throttle)
TB1-10 Rev In (Reverse input? Ditto with throttle)
TB3-1 +12v VCC (Appears to be 12v after the protection diode, versus 12v input. Connected to inverter too?)
TB3-2 GND
TB3-3 Phase U
(PWM signals for that phase that create the waveform that the inverter then boosts to motor-size voltages and currents?)
TB3-4 Phase Y
TB3-5 Phase W
TB3-6 Current U
TB3-7 Current Y
TB3-8 MG2 Enable
TB3-9 MG2 Fault
TB3-10 DC Bus
TB2-1 +5V VCC (Again just from this board's regulator, redundant wire to TB1-3?)
TB2-2 ENCA In (Encoder inputs?)
TB3-3 ENCB In
TB3-4 GND
TB3-5 HS Temp
TB3-6 MOT Temp
TB4-1 GND
TB4-2 Main Con
TB4-3 Precharge
TB4-4 +12 V VCC (Redundant to TB2-1?)
TB4-5 CAN L
TB4-6 CAN H
32-pin Prius Inverter Pinout: (Add photo of plug showing pin numbering? Where does numbering start?)
Pin # Designation Wire Color Description
1 Example Example Example
2 Example Example Example
3 Example Example Example
4 Example Example Example
5 Example Example Example
6 Example Example Example
7 Example Example Example
8 Example Example Example
9 Example Example Example
10 Example Example Example
11 Example Example Example
12 Example Example Example
13 Example Example Example
14 Example Example Example
15 Example Example Example
16 Example Example Example
17 Example Example Example
18 Example Example Example
19 Example Example Example
20 Example Example Example
21 Example Example Example
22 Example Example Example
23 Example Example Example
24 Example Example Example
25 Example Example Example
26 Example Example Example
27 Example Example Example
28 Example Example Example
29 Example Example Example
30 Example Example Example
31 Example Example Example
32 Example Example Example
