Toyota Prius Gen2 Board
Revision as of 15:36, 14 December 2019 by Jack Bauer (talk | contribs)
Prius Board v1
The Toyota Prius Gen2 Board is an open source project to repurpose 2004-2009 Toyota Prius inverters for DIY EV use. It consists of a circuit board and programming that replaces the Prius' original ECU.
Prius Inverter
Prius Gen 2 Inverter Montage
  • Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
  • 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
How To Use
The control board utilizes the Blue Pill (link?) microcontroller, and takes advantage of the OpenInverter.org software (link?) for control.
Pin Header Summary
Control Board Description:
Pin # Designation Description
TB1-1 12v-in Primary 12v supply from ignition on
TB1-2 GND Primary ground connection to 12v negative. All grounds are common
TB1-3 5v VCC 5V supply from board for use with throttle pot or hall pedal
TB1-4 Throttle In 0-5v variable voltage input from throttle pedal or pot
TB1-5 Regen In 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor
TB1-6 GND
TB1-7 Brake In 12v digital input from brake light switch.
TB1-8 Start In 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used.
TB1-9 For In 12v digital input commands motor to run in forward direction
TB1-10 Rev In 12v digital input commands motor to run in reverse direction
TB3-1 +12v VCC 12v output to inverter IGCT terminal
TB3-2 GND Common ground
TB3-3 Phase U
Phase U output. Connect to Inverter MUU terminal for MG2 inverter drive or GUU for MG1 inverter drive
TB3-4 Phase Y Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive
TB3-5 Phase W Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive
TB3-6 Current U Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-7 Current Y Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-8 MG2 Enable Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter
TB3-9 MG2 Fault Connect to MFIV for MG2 or GFIV for MG1
TB3-10 DC Bus Connect to inverter VH to measure DC link voltage
TB2-1 +5V VCC 5v output to encoder for induction motor
TB2-2 ENCA In Encoder input A
TB2-3 ENCB In Encoder input B
TB2-4 GND Encoder ground
TB2-5 HS Temp Heatsink temp sensor input
TB2-6 MOT Temp Motor temp sensor input
TB4-1 GND Common ground
TB4-2 Main Con Main HV contactor control low side switch
TB4-3 Precharge HV precharge contactor control low side switch
TB4-4 +12 V VCC Spare 12v output
TB4-5 CAN L Can bus low signal
TB4-6 CAN H Can bus high signal
32-pin Prius Inverter Pinout: (Add photo of plug showing pin numbering? Where does numbering start?)
Pin # Designation Wire Color Description
1 NC
2 GIVA Example Example
3 GIVB Example Example
4 GUU Example Example
5 GVU Example Example
6 GWU Example Example
7 MIVA Example Example
8 MIVB Example Example
9 MUU Example Example
10 MVU Example Example
11 MWU Example Example
12 VH Example Example
13 CPWM Example Example
14 GSDN Example Example
15 VL Example Example
16 GINV Example Example
17 NC Example Example
18 GIWA Example Example
19 GIWB Example Example
20 CT Example Example
21 GIVT Example Example
22 GFIV Example Example
23 MIWA Example Example
24 MIWB Example Example
25 MSDN Example Example
26 MIVT Example Example
27 MFIV Example Example
28 OVH Example Example
29 CSDN Example Example
30 FCV Example Example
31 OVL Example Example
32 GCNV Example Example
