VW Touran Conversion
I will start loosely collecting infos on the VW Touran from 2004.
Throttle Pedal
The throttle pedal is analog, its signals are put onto the CAN bus by the ECU. I chose to remove the latter so I will have to look into reading the pedal directly. Here is its pin map:
| Pin # | Color code | Function |
| 1 | green/white | 5V |
| 2 | yellow/green | 5V |
| 3 | brown/blue | GND |
| 4 | white/blue | Throttle 1 0.75V-4.1V |
| 5 | green/blue | GND |
| 6 | blue/black | Throttle 2 0.38-2.05V |
ECU connector
| 11 | - | Throttle GND (Pin 5) |
| 12 | Throttle 2 out (Pin 6) | |
| 13 | Throttle 5V (Pin 1) | |
| 33 | Throttle GND (Pin 3) | |
| 34 | Throttle 1 out (Pin 4) | |
| 35 | Throttle 5V (Pin 2) | |
| 31 | Vacuum sensor GND | |
| 37 | Vacuum sensor 5V | |
| 83 | Vaccum sensor signal | |
| 86 | Ignition On - provides enough power to run the main board | |
| 87 | While the ECU was connected, bridging this signal to 12V engaged the main 12V supply of the ECU. This behaviour could not be reproduced without ECU | |
| 67 | CANL | |
| 68 | CANH |
Power steering
As soon as you produce CAN message 0x280 it expects rpm to be above about 600rpm, otherwise there is no power steering.
CAN bus
| COB Id | Len | Function | Notes |
| 0x1A0 | 1 | Byte 1, Bit 3: Brake pedal switch | Produced by whoever |
| 0x280 | Bytes 2 and 3: RPM*4 | Produced by you, Controls the rpm gauge | |
| 0x284 | 6 | Byte 0, 1: Counter 0-F in each
Byte 2-5: 0 |
20ms |
| 0x288 | Byte 0: sequence 0x27, 0x46, 0x8F, 0xD7
Byte 1: Temp Gauge 4/3 x temp + 48 |
Produced by you, Controls temp gauge. Gain 4/3, offset 48 | |
| 0x380 | 8 | Byte 0: 0
Byte 1: 0x65 Byte 2: Throttle 0-0xFE Byte 3-6: 0 Byte 7: Throttle delayed or filtered maybe + idle throttle as it's never 0 |
It's not actually that constant but apparently sufficient for DSC |
| 0x38A | Byte 1, Bit 0: Cruise on/off, Bit 1: Disable button, Bit 2: Set-, Bit 3: Set+ | ||
| 0x480 | 8 | Byte 0: sequence 0x10, 0x68, 0x94, 0xC0
Byte 1, Bit 2: EPC, Bit 3: engine Bytes 3,4: Consumption signal - incremental. Increasing by 28 results in 10l/h Byte 5: 0 Byte 6, Bit 2: Cruise light, Bit 4: Message "Motorstörung Werkstatt!" Byte 7: XOR of Bytes 0-6 |
Controls various indicator lights and fuel consumption display |
| 0x488 | 8 | Byte 0: Counter 0-F << 4 + 8
Byte 1-4: 21, 21, 7E, A6 Byte 5-6: 0 Byte 7: Counter 0-F << 4 |
| 0x572 | Byte 0, Bit 3: Key switch in start position | ||
| 0x580 | 8 | Byte 0: 0x80 + counter 0-F
Byte 1, 2: 0 Byte 3: sequence 0x0f, 0x28, 0x7f, 0x28 Byte 4: sequence 0x1e, 0x10, 0x00, 0x10 Byte 5: sequence 0x70, 0x56, 0xf0, 0x56 Byte 6: sequence 0x0c, 0x48, 0xa7, 0x48 Byte 7: sequence 0x46, 0x90, 0x28, 0x90 |
100ms |
Faults
After powering up the engine I got two error messages: STOP low coolant and something about an oil sensor. The first can be solved by filling the reservoir with water. The second is probably down to the missing oil level sensor. I will investigate.
Update on oil level warning: I fitted a 1k2 Ohm resistor from pin 2 to pin 3 (generates 2.5V "oil level") and the warning is gone.
Update 2: no it's not gone, it's a bit more complex. Read https://wak-tt.com/guides/ttc.pdf page 84. Maybe I can tell the dash panel to ignore the sensor.
Update 3: successfully programmed the instrument cluster to ignore the missing sensor. You need a CAN OBD adapter with matching software. Then in adaptation channel 39 change value to 0 (=sensor not present). Found here: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Instrument_Cluster
DSC light
A bit harder to fake was the messages for the ABS/DSC system. It seems all messages originally produced by the ECU need to be on the bus. That is Ids 0x280, 0x284, 0x288, 0x380, 0x480, 0x488, 0x580 and 0x588. So far it seems their content doesn't have to match exactly. I will update the table above.
