ZombieVerter VCU
V1 Now available for general sale here.
- STM32-CAR project
- Openinverter
- ISA library
- Throttle cal and mapping,
- Temp derating,
- BMS limits,
- for/rev/neutral control,
- Graphing and monitoring,
- Cruise control,
- Fuel gauge driver,
- etc
The current list of parts to be fitted:
CONN1
IC10 = MCP25625T
IC14 = TJA1020 OR MCP2004
IC19 = NCV7356
IC20 = TJA1055T
IC21, 22 = AD5160
IC27, 28, 29 = FAN3122And the positions on the V1 board.
The enclosure kit links
- Enclosure Kit with Header, connector and pins :
- Prewired connector with 3M leads (limited colors which will not match standard wire colouring conventions) :
| Video | Highlights |
| <youtube>https://www.youtube.com/watch?v=geZuIbGHh30</youtube>
00:33 Warning and suggestion to go watch cat videos instead |
06:00 IC10 - SPI CAN controller and transceiver (MCP25625T) |
| <youtube>https://youtu.be/MUhs9j9R9Mg</youtube>
00:34 Health warning and suggestion to go watch cat videos instead |
11:00 Pins 25,26,27,28 - 3 CAN bus interfaces. CAN EXT is for vehicle/body communication, |
ZombieVerter VCU V1 Part 3
| <youtube>https://youtu.be/oPb4vMO17B4</youtube>
00:38 Intro/Recap of part 2 18:13 V1 ISA shunt connection to PDM after the contactors/precharge system to monitor high voltage applied to the drivetrain |
21:55 Leaf PDM Internals, starting with high voltage connections |
Installation
Pin Out Diagram
Wifi Setup
NOTE: Recent units have a new wifi module that isn't automatically assigning an IP via DHCP. See this thread for details, and if you can help resolve the issue. Until then, you need to manually assign an IP of 192.168.4.2 (anything other than 192.168.14.1 on the 192.168.4.0/24 subnet) to your device.
Configuration Setup
- Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel. Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
- Note: Leaf VCU requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
Software
Various binaries can be found in the support thread, for example https://openinverter.org/forum/viewtopic.php?p=33379#p33379
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
./Stm32-vcu/libopeninv/src/
Software update
If you are unable to build your own, use the stm32_vcu.bin that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
If you are unable to build your own, use the stm32_vcu.hex that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
Initializing an ISA Shunt
Supported OEM Hardware
- chevy volt HV water heater
- BMW E46 CAN support
- BMW E39 CAN support
- BMW E65 CAN Support
