ZombieVerter VCU
V1 Now available for general sale here.
What we have as of now is the openinverter wrapper with things like :
  • Throttle cal and mapping,
  • Precharge and contactor control,
  • Temp derating,
  • BMS limits,
  • for/rev/neutral control,
  • Graphing and monitoring,
  • Firmware updates via the web interface,
  • Cruise control,
  • Fuel gauge driver,
  • etc
The current list of parts to be fitted:
CONN1
IC10 = MCP25625T
IC14 = TJA1020 OR MCP2004
IC19 = NCV7356
IC20 = TJA1055T
IC21, 22 = AD5160
IC27, 28, 29 = FAN3122
And the positions on the V1 board.
The enclosure kit links
Enclosure Kit with Header, connector and pins :
Prewired connector with 3M leads (limited colors which will not match standard wire colouring conventions) :
Video Highlights
00:33 Warning and suggestion to go watch cat videos instead
01:06 Recap about the ZombieVerter VCU Build Part 1
03:04 How to get one
03:35 Design files currently require E10 Patreon membership/contribution if wanting to build your own
04:28 Components still requiring soldering
05:03 IC19 - 8 pin SOIC for single wire CAN (NCV7356)
06:00 IC10 - SPI CAN controller and transceiver (MCP25625T)
06:30 IC1,3,5,6,7,24,25,26 load driver mosfets (NCV8402)
07:20 Do you need these components?
08:40 Soldering begins - IC19
09:10 Soldering iron for SOIC parts
09:27 Applying flux using Damien's favorite Flux, UV80
10:34 Magnifier headset
13:27 Soldering MCP25625
15:55 Suggests getting an phone/computer repair shop to help out if needed
17:05 Using hot air gun to warm the board and position the chip
19:34 Soldering NCV8402s
23:28 Clean soldering with IPA Solvent
24:40 First power up test using bench power supply to limit current to a few hundred mA
26:47 60mA current draw with no wifi board
27:35 Wifi module
29:50 Power up test with wifi draws 90mA
30:25 Enclosure kit(s)
36:02 Soldering the PCB header (56 pin)
44:28 Installing in the enclosure
50:30 Cameo appearance by Gome cat
Video Highlights
00:34 Health warning and suggestion to go watch cat videos instead
01:42 Intro
03:20 Pinouts of the 56 pin connector
04:16 Pins 55,56 - Ground and +12V
04:49 Pins 53,54 - Reverse and Forward Direction. Apply +12V to the pin for the direction needed.
Configurable in the web interface to flip these since direction is relative
07:32 Pins 52 - Start. Momentarily apply +12V to send a start signal
08:15 Pin 51 - HV Request. Apply +12v to precharge and bring up the high voltage system
(and not the drive components)
09:05 Pin 50 - General Purpose 12V Input. Reserved for future use
09:23 Pin 49 - Brake Input. Connect to brake light switch to apply +12V signaling brakes are applied
10:15 Pins 45,46,47,48 - Throttle. +5V power, ground, and 1 or 2 hall effect sensor inputs
11:00 Pins 25,26,27,28 - 3 CAN bus interfaces. CAN EXT is for vehicle/body communication,
CAN EXT 2 for the ISA shunt comms,
CAN EXT 3 (with solderable jumpers to change modes) is for general purpose like charger, heater control
14:45 Pin 24 - Local Interface Network (LIN)
15:56 Pins 16,17,18,19,20,21,22,23 - Toyota Hybrid Inverter specific using async serial comms.
17:21 Pin 15 - Ignition T15 In. Apply +12V to turn Ignition on. Puts VCU in run mode
18:54 Pins 37,38,39,40,41,42 - Toyota Hybrid Transmission shift control
19:42 Pins 35,36 - POT1 & POT2. Digital potentiometer outputs to drive analog gauges (fuel, etc)
21:10 Pins 32,33,34 - Low Side (LS) switches for Inverter Power, Positive side Main Contactor, Precharge Contactor
23:21 Pin 31 - General Purpose +12V Output. LS switch for Negative side Main Contactor
24:01 Pins 12,13,14,29,30 - Toyota Hybrid System controls
25:24 Pins 10,11 - Digital to Analog Converter (DAC) 1 & 2. Reserved for future use - additional analog instruments etc.
26:33 Pins 8,9 - 0-5V Analog Inputs 1 & 2. Reserved for future use (ie not implemented yet)
27:06 Pins 5,6,7 - Pulse Width Modulation (PWM) 1-3 +12V output signals. Reserved for future use (ie not implemented yet)
27:56 Pins 3,4 - General Purpose +12V Outputs 2 & 3. Reserved for future use (ie not implemented yet)
28:29 Pins 1,2 - RS232 Rx/Tx Serial connection for alternation VCU communication (solder jumper configurable). Reserved for future expansion
30:11 CAN bus connected Isabellenhutte Huesler Shunt
38:45 Web Interface
44:10 How to perform a software update via the web interface using a precompiled binary
47:32 UI Features - Commands
52:50 UI Features - Update
53:30 UI Features - Parameters
1:11:32 UI Features - Spot Values
1:21:54 Epilogue
ZombieVerter VCU V1 Part 3
Video Highlights
00:38 Intro/Recap of part 2
01:04 Description of 2018 Nissan Leaf components used in the video
03:47 VCU, wiring harness, 12V battery, ISA shunt, contactors
07:06 12V battery - negative to chassis ground with fuse, and ground to VCU pin 55
07:52 12V battery - positive to PDM positive terminal and distribution block
08:42 12V battery - permanent fused +12v from PDM positive terminal to inverter and PDM
09:14 12V battery - permanent fused +12v to vcu, relay controlled by VCU for switched +12v to inverter and PDM
10:41 12V battery - permanent fused +12v to contactor coil positives
10:57 12V battery - permanent fused +12v to switch to provide things like T15 on signal to VCU
12:42 Other end of permanent 12v feed to inverter and PDM connections
13:23 Other end of switched +12v feed to inverter and PDM connections
13:36 Other end of switched 12v ground connection
13:52 Twisted pair wires from EV CAN CAN EXT 2 High (pin 28) and CAN EXT 2 Low (pin 27) to inverter
15:46 To use the PDM for charging, wire control pilot (CP) and plug present (PP) from PDM to charge socket
16:29 High voltage setup and controlling it with the VCU
17:08 Positive and precharge contactors (only 2 for the test rig - usually would have a negative contactor as well)
17:40 High voltage positive and negative junction. The ISA shunt connected between negative and PDM to distribute high voltage negative to the components
18:13 V1 ISA shunt connection to PDM after the contactors/precharge system to monitor high voltage applied to the drivetrain
18:51 Contactor control using negative side connections via VCU (very brief description)
21:55 Leaf PDM Internals, starting with high voltage connections
23:08 Leaf PDM Internals, single phase AC charging connections
23:49 CCS type 2 socket connections
24:50 Gome Cat comes in to say hello
25:45 Control switches. +12v, forward input, terminal 15 input, start input, high voltage request input.
26:24 Step 1 is close switch providing +12v to the forward input and T15 connections to enable "ignition on" mode
26:45 Step 2 is toggle start input to activate precharge, closing of main contactor, and inverter main relay (assuming all conditions are met)
27:25 Example throttle from mid 2000s BMW. Two channel hall effect sensor
28:46 Charging description when plugging in charger cable
29:31 Throttle Calibration using spot values for pot and pot2 in auto refresh mode while pressing the pedal across it's range, noting the min/max and recording the min+10 for potmin, and max-10 for potmax for each pot under parameters. Also select dual channel potmode if using two channels (will not work in single channel mode with 2 channels wired up)
37:37 Running the motor
40:07 Checking status, observing parameters
47:44 Problems/gotchas - PRECHARGE error (no high voltage supply, udc not > udcsw within 5s)
50:16 Problems/gotchas - too high udcmin setting and no motor spin, potum will not go positive
53:59 Problems/gotchas - too low udcmax (max voltage to allow regen) - motor spins without slowing when throttle released
56:13 Explanation of udclim as redundant cutoff voltage to shut off contactors
56:40 Explanation of idcmax and idcmin current limits
57:00 Explanation of tmphsmax heatsink max temp too low, and min setting allowed of 50C
59:08 Problems/gotchas - throtmax too low, no motor spin
1:01:46 Charging example using Leaf_PDM - seems incomplete, see below
1:03:00 Wifi Connection to the VCU and upgrading firmware
1:06:23 Resolve update fail/hang - activity led stops flashing, no data on web interface (power cycle)
1:10:25 Gome cat in it's natural habitat
1:13:19 Causes of wifi issues
1:16:49 Initializing the ISA shunt
1:20:55 Demonstrating regen
1:22:11 Automatic charge start/stop using Leaf PDM
1:24:03 Epilogue
Installation
Pin Out Diagram
VCU pinout diagram
List of connections to system components (GS450 application)
Wifi Setup
NOTE: Recent units have a new wifi module that isn't automatically assigning an IP via DHCP. See this thread for details, and if you can help resolve the issue. Until then, you need to manually assign an IP of 192.168.4.2 (anything other than 192.168.14.1 on the 192.168.4.0/24 subnet) to your device.
Configuration Setup
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel. Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
  • Note: Leaf VCU requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
Software
Various binaries can be found in the support thread, for example https://openinverter.org/forum/viewtopic.php?p=33379#p33379
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
That recursively pulls in copies of libopeninv, etc and tracks them...   Hence your file-path should look like
./Stm32-vcu/libopeninv/src/
Software update
If you are unable to build your own, use the stm32_vcu.bin that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
If you are unable to build your own, use the stm32_vcu.hex that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
Initializing an ISA Shunt
Supported OEM Hardware
  • Nissan Leaf Gen1/2/3 Inverter/ motor
  • nissan leaf gen 2 drive stack (inverter, dcdc, charger) gen 3 coming soon
