The LIM is also available new from BMW spare parts suppliers for € 240. If you get it new it comes without firmware and it needs to be programmed first.
External links
> CAN logs
Connectors and Pinouts
| 1B | 16 Pin Connector | Hirschmann 805-587-545[2] |
Audi 7M0 973 119 |
| 1B-2 | - | |
| 1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
| 1B-10 | GND | Ground |
| 1B-11 | - | |
| 1B-12 | - | |
| 1B-13 | - | |
| 1B-14 | - | |
| 1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
| 2B-1 | CP | Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! |
| 2B-2 | PP | Proximity (charge port) |
| 2B-3 | Jumper | Connected to Pin 4 |
| 2B-4 | Jumper | Connected to Pin 3 |
| 2B-5 | GND | Ground (charge port) |
| 2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
| 4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance needs to be ~15 ohms) |
| 4B-2 | NEG_CONT+ | Negative HV Contactor Control |
| 4B-3 | POS_CONT- | Positive HV Contactor Control |
| 4B-4 | NEG_CONT- | Negative HV Contactor Control |
| 4B-5 | U_HV_DC | Charge Port DC Voltage (current input 3-20mA?)(1.42V for 0V HV, linear to 4.8V for 500V HV)[8] |
| 4B-10 | COV_MOT- | Charge Port Cover motor (Not necessary) |
| 4B-12 | COV_FB | Charge Port Cover Feedback (connect to GND to simulate open cover[9])(To be left floating for contactors weld test) |
Wiring Diagram
Note [18Jun2022 ALS]: In the above diagram, some details may be non-current, eg the Charge Port Cover sensor is not shown, but its line @ 4B-12 must be floating (signalling that the Charge Port Cover is closed (?)) in order for the LIM to proceed with its welded contact tests; 4B-12 is tied to Ground (?) to indicate that the cover is open[10].
Wiring notes
This board needs to produce an isolated 3-20mA current signal (or: 1.42V for 0V HV, linear to 4.8V for 500V HV)[11] from the high voltage DC voltage.
A circuit of a voltage sense board is shared here and can be purchased here. Alternative board is available here.
Fast charge contactor
Larger contactor control
Charge port
Charge port lock
- Connector shell: BMW 12527549033 (ref. jon volk)
- Terminals: BMW 61131393724
RGB charge indication light
Programming a new LIM
If you order a new LIM there is no configuration loaded but our hero Damien managed to program a brand new LIM with a i3 BDC (Body Domain Controller).
https://openinverter.org/forum/viewtopic.php?p=43848#p43848
He caught a CAN log of the programming session https://github.com/damienmaguire/BMW-i3-CCS/tree/main/Programming/Logs
Hopefully we figure out how to do it with a few CAN messages. Otherwise he might offers LIM programming as a service.
- Software : Esys 3.36 from here : https://disk.yandex.ru/d/3XLfVVYHFq8qQw
- pszdata lite from here : https://disk.yandex.ru/d/Y0w0r5T1ElMVdA
- Hardware : LIM (duh!), connectors and pins.
- BMW i3 BDC (Body Domain Controller) basically the main ecu in the i3 the gates all the data around the car. https://www.evbreakers.com/
- Car key from the same car as the BDC.
- BDC simulator : https://www.aliexpress.com/item/1005002317110375.html
- Enet cable : https://bcables.com/
- USB to ethernet adapter if your PC / laptop does not have a spare ethernet port.
Charge control
Contactor Test
- Fault set in 0x272 byte 2
- Ignition in 0x12F byte 2 needs to toggle from to OFF 0x88 to ON 0x8a
CCS inlet temperature sensors
CAN communication
| 0x112 | BMS msg. | VCU or BMS | 10ms | could also be sent by BMS |
| 0x2FC | Charge flap control | VCU | 100ms | needed (constant values work) |
| 0x03C | Vehicle status | VCU | 200ms | (constant values) needed? |
| 0x1A1 | Vehicle speed | VCU | 20ms | (constant values) 10ms works needed? |
| 0x2A0 | Central locking | VCU | 200ms | (constant values) needed? |
| 0x397 | OBD | VCU | 200ms | (constant values) needed? |
| 0x3F9 | Engine info | VCU | 200ms | (constant values) needed? |
| 0x3A0 | Vehicle condition | VCU | 200ms | (constant values) needed? |
| 0x330 | Range info | VCU | 200ms | (constant values) needed? |
| 0x512 | Network management edme | VCU | 200ms | (constant values) needed? |
| 0x560 | Network management kombi | VCU | 200ms | (constant values) needed? |
| 0x3E8 | OBD reset | VCU | 1s | (constant values) needed? |
| Messages sent by LIM | ||||
LIM logs
Observations
LIM hardware
LIM versions
| Part No. | IEC 61851
J1772 (AC) |
| 61 35 6 828 052 | BMW i3 | Aug 2019[12] | |||||
Mini cooper SE |
now |
Power Limits
Chips on the LIM board
Charging protocols
Signaling circuit
AC charging
CCS DC charging
