EV Conversion Parts
Revision as of 01:38, 21 September 2022 by Mark (talk | contribs) (Power Steering: Added additional power steering pages to the list)
Motors
AC Induction Motors
  • Siemens 1PV5135-4WS14
PMSM (Permanent Magnet Synchronous Motors)
These Requires FOC Firmware.
There is a more general motor list as well.
Batteries
CALB
LG Chem - BMW Hybrid
LG Chem - BMW I3
LG Chem - Chevy Volt
LG Chem - Chrysler Pacifica Hybrid
Tesla
Brakes
Vacuum Boosted
Vacuum Pumps
Vacuum pumps are available via several OEM and 3rd party manufacturers. Some options may include:
Vacuum Sensors:
  • BOSCH 0 265 005 331 / 13581083
    • Pin 3 - 5V
    • Pin 2 - Gnd
    • Pin 1 - Value - 0.48v under no vacuum
    • Seems to have checkvalve built in.
Electrically Boosted:
There are a couple of options for electrically boosted braking systems, with one of the most popular being the Bosch iBooster.
More info on using the iBooster is available here, and pinouts for the Tesla versions here
iBooster gen1 connectors:
Main connector (26-pin): Bosch "EuCon" 26p
  • Main housing: 1928405762
  • Cover: 1928405765
  • Pins: Bosch BTC Terminal
    • 1928498807 - BTC 4.8 / Terminal Sn / > 2.5 - 4.0 mm² (main power: pins 1 & 9)
    • 1928498806 - BTC 2.8 / Terminal Sn / 1.5 - 2.5 mm² (constant power: pin 17)
    • 1928498705 - BTC 1.5 / Terminal Sn / 0.35 - 0.5 mm² (ignition power: pin 20; signal pins 2, 8, 22, 23)
    • 1928498805 - BTC 1.5 / Terminal Sn / 0.5 - 1.0 mm² (larger diameter alternative to 1928498705 above)
  • Seals: Bosch BTC
    • 1928301086 - BTC 4.8 / Seal / Blue (∅ 3.4 - ∅ 3.7 mm)
    • 1928301206 - BTC 2.8 / Seal / Reddish Brown (∅ 2.0 - ∅ 2.7 mm)
    • 1928301083 - BTC 1.5 / Seal / Grey (∅ 1.6 - ∅ 1.9 mm)
  • Plugs: Bosch BTC
    • 1928301207 - BTC 2.8 / Plug / Green
    • 1928301087 - BTC 1.5 / Plug / White
Sensor connector (4-pin): TE MQS
  • Housing: 1-967640-1
  • Pins: 5-965906-5 (20 - 18 AWG)
  • Seals: 1-967067-1 (∅ 1.4 - ∅ 2.1 mm)
iBooster Sourcing
VAG (VW, Audi, Porsche) part numbers:
Part Number Generation Models available in
5QE614105AH Volkswagen e-Golf (2016-2018)
Audi A3 Sportback e-tron (2017)
5QE614105AK Gen 1 Volkswagen e-Golf (2016-2018)
Volkswagen Passat GTE (2017)
Volkswagen Golf GTE (2017)
5QE614105AN Gen 2 Volkswagen e-Golf (2018-2019)
5QE614105AQ Gen 2 Volkswagen e-Golf (2018-2019)
5QE614105S Volkswagen e-Golf (2016-2018)
Tesla part numbers:
1037123-00-A Gen 1 Tesla Model S
Tesla Model X
1037123-00-B Gen 1 Tesla Model S
Tesla Model X
1044671-00-D Tesla Model 3
1044671-00-E Gen 2 Tesla Model 3
An alternative list (mostly the same) of iBooster donors can be found here: https://www.evcreate.nl/ibooster-donor-vehicles/
Charger
Built-In
Chevy Volt / Lear
Tesla Gen 2 10kW(?)
Tesla PCS
Mitsubishi Outlander PHEV
Contactors
Panasonic AEV14012
DC/DC
Chevy Volt / Lear
Prius Inverters
tesla model s
High Voltage Junction Box
Building a junction box
Power Steering
Opel Electric Power Steering Column
Opel Power Steering Pump
VW Electromechanical Power Steering Rack
