Toyota/Lexus MGR Rear Transaxle Motor
Revision as of 11:32, 15 December 2022 by Crasbe (talk | contribs) (Added References section)
For conversion/project purposes the MGR is suitable for lighter models given the torque available or could potentially be used front and/or rear, and/or with a secondary motor.
As the motor was designed to be used occasionally as a rear motor, potential need for additional cooling dependent on the application
active forum thread: https://openinverter.org/forum/viewtopic.php?f=14&t=190
part numbers and there stated output:
Q210-1FM[1]
Power/Torque output: (18 kW / 108 Nm)
Gear ratio: 6.311:1 (Estima), 6.859:1 (Alphard)
Layout: 3-shaft
Capacity - 1.5 l (ATF Type T-IV)
Q211-2FM[1]
Peak Power:/Torque output: (50 kW / 130 Mm or 139 Nm)
Gear ratio: 6.859:1 (1st stage 23:40, final gear 18:71)
Layout: 3-shaft
Capacity - 1.8 l (ATF WS)
Module weight - 41.8 kg
Q510-1MM[1]
Peak Power:/Torque output: (5.0 or 5.3 kW / 55 Nm or 2.2kW/44nm, 201V), induction type
Gear ratio - 10.487:1 (1st stage - 17:39, final gear - 14:64)
Layout: 2-shaft (motor is coaxial with differential)
Capacity - 1.2-1.3 l (ATF WS)
Module weight - 29.2 kg
Q610-4NM[1]
Peak Power:/Torque output: (40 kW / 120 Nm)
Gear ratio - 10.781 (1st stage - 15:41, final gear - 18:71)
Layout: 3-shaft
Differential with pre-load spring washers
Capacity - 1.7 l (ATF WS)
Module weight - 41.1 kg
these trans axles can be found on a variety of lexus and toyota vehicles:
Q210:
  • Alphard ATH10
  • Estima AHR10
Q211:
  • Alphard/Vellfire ATH20
  • Alphard/Vellfire AYH30
  • Estima AHR20
  • Harrier MHU38
  • Harrier AVU65
  • Highlander MHU28
  • Highlander MHU48
  • Highlander GVU48
  • Highlander GVU58
  • Kluger MHU28
  • Lexus RX400h MHU38
  • Lexus RX450h GYL15
  • Lexus RX450h GYL25
  • Lexus NX300h AYZ15
  • RAV4 AVA44
Q510:
  • Camry AXVH75
  • Corolla ZWE214W
  • Corolla Touring ZWE214W
  • Lexus UX250h MZAH15
  • Prius ZVW55
  • Yaris MXPH15
  • Yaris Cross MXPJ15
Q610:
  • RAV4 AXAH54
  • Highlander AXUH78
