Tesla Model 3 Battery
Revision as of 00:35, 3 February 2023 by Bratitude (talk | contribs)
Tesla Model 3 Battery Hacking
hv controller connector
pinout from HV controller
model 3/y battery uses custom versions of the LTC6812 chips for voltage sensing dubed "batman"
bms boards talk via a modified version of isospi
Damien Maguire has developed 2 different unfished approaches to communicating directly with the cell level boards:
https://www.evbmw.com/index.php/evbmw-webshop/tesla-boards/tesla-model-3-bms
https://www.evbmw.com/index.php/evbmw-webshop/tesla-boards/tesla-model-3-bms-batman
broken isospi connector
HV controller
Model 3 High Voltage Controller
the HV controller located in the penthouse controls the PCS, contactors, pyro fuse, talks to the bms boards, etc
reading cell voltages and controlling contactors can be done by talking to the HV controller over CANbus
you can read cell temps and voltages with scanmytesla and hooking up a obd connector to the hv controller canbus
the HV matting connector is:
Sumitomo TS Sealed Series
6189-6934
6189-7077
see thread post https://openinverter.org/forum/viewtopic.php?p=31886#p31886
useful links:
https://github.com/commaai/opendbc
https://teslamotorsclub.com/tmc/threads/reading-battery-voltages-and-temperatures-via-can-on-model-s.60509/
reading canbus data
Arduino sketch for due based boards:
https://openinverter.org/forum/download/file.php?id=15866
libraries needed:
make a s folder named "msgid6f2" in ardunio/libraries and put these two files there:
https://openinverter.org/forum/download/file.php?id=20710
https://openinverter.org/forum/download/file.php?id=20709
