The LIM is also available new from BMW spare parts suppliers for € 240. If you get it new, it comes without firmware loaded, and it must be programmed first.
External links
> CAN logs
Connectors and Pinouts
| 1B | 16 Pin Connector | Hirschmann 805-587-545[2] |
Audi 7M0 973 119 |
| 1B-2 | - | |
| 1B-10 | PE / GND | Ground |
| 1B-11 | - | |
| 1B-12 | - | |
| 1B-13 | - | |
| 1B-14 | - | |
| 1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
| 2B-1 | CP | Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! | Pilot (charge port) |
| 2B-3 | Jumper | Connected to Pin 4 | GND |
| 2B-5 | GND | Ground (charge port) | Connected to Pin 4 |
| 2B-6 | US CCS1 version connected to 2B-2 | N/C (TBD if used for US CCS1) |
3B Pinout:
- N/A (for CHAdeMO only)
Wiring Diagram
Wiring notes
This board needs to produce an isolated 3-20mA current signal (or: 1.42V for 0V HV, linear to 4.8V for 500V HV)[12] from the high voltage DC voltage.
Fast charge contactor
Larger contactor control
Charge port
Make sure to match these if you want to use a different charge port. Some brands use different resistance values.
Charge port lock
- Connector shell: BMW 12527549033[13] or Hirschmann 805122541[14]
- Terminals: BMW 61131393724
RGB charge indication light
Wake/sleep
- On plug insertion.
Programming a new LIM
If you order a new LIM there is no configuration loaded but our hero Damien managed to program a brand new LIM with a i3 BDC (Body Domain Controller).
https://openinverter.org/forum/viewtopic.php?p=43848#p43848
- Software:
- Hardware:
- Car key from the same car as the BDC. EDIT: this may not be necessary as the BDC can be put into "on" mode by running the full fault delete function using ISTA [15]
Charge control
Contactor Test
- Fault set in 0x272 byte 2
CCS inlet temperature sensors
CAN communication
| Messages sent by LIM | ||||
LIM logs
Observations
LIM hardware
Physical dimensions
LIM versions
| Part No. | IEC 61851
J1772 (AC) |
| 61 35 6 828 052 | BMW i3 | Aug 2019[16] | |||||
Mini cooper SE |
now |
Power Limits
Chips on the LIM board
Charging protocols
Signaling circuit
AC charging
CCS DC charging
