Tesla Model S GEN1 Charger
The Tesla GEN1 on-board AC charger (OBC) was a single phase 10kW AC charger that was fitted originally and primarily in the Tesla Model S, from Jun2012 through Sep2013, when it was replaced with GEN2. GEN1 models are easy to identify, having the word "TESLA" stamped on the top metalwork and having no black anti-tamper tape; the GEN2 charger lacks the Tesla identifier stamped on the metalwork, and has anti-tamper tape over the seams.
The charger is made up of three 3.3 kw modules, each mounted to a liquid-cooled heat sink that forms the bottom plate/base. This assembly enables single phase AC charging only.
The GEN1 chargers are considered to be more trouble-prone than the later units, and are not as popular for use in EV conversions or ground-up builds, partly because they do not support 3-phase AC input. However, they are used in many OEM installations that continue to need servicing. Examples of OEM installs include Telsa (2012-Sep2013 Model S), Toyota (2012-14 RAV4 EV[1]), and Mercedes Benz (2014-17 B250e[2]). As far as is known, these are identical from a hardware perspective[3], but the firmware does differ and is not interchangeable between installations.
Charger Connectors
- Logic (X042 or X043)
- AC (Input)
- DC (Output)
In typical applications, not all six connectors may be in use:
For Logic Connector X042 (X043, when referred to when provisioned in "Slave" duty), the mating connector needed to plug into the charger is Molex 19418-0026[4] which is in the MX150L series. This connector features CPA[5] (Connector Position Assurance), a dual-locking feature. For bench-testing, etc., the non-CPA connector is Molex 19418-0038[6]; this connector requires one less operation to disengage, but is less suitable for automotive use or environments where heavy vibration is present.
Wire size * |
Telsa
Wire Color * |
6 | FC CAN | AKA "FC_CAN". Possibly SWCAN. Connects to BMS "FC_CAN+" | 20 AWG (0.5mm²) | RD-WH |
12 | "BMS_12V_in" | "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables charger?) | 18 AWG (0.75mm²) | RD-GY |
When an OBC is provisioned as a Second OBC ("Slave"), the Logic connector is populated with a reduced wire count, as the First OBC ("Master") handles all external interfaces.
DC (Output) Connector
AC (Input) Connector
See above DC Output Connector above terminals; it uses the same female terminals.
HVIL Connector "J5"
- J5 HVIL: Only the outside pins are in use. These are used to integrate the HVJB's Lid Reed Switch into the HVIL loop, and this is connected to the HVJB's Lid Reed Switch if the OBC is the only (single) or Master (dual) OBC.
- For Slave OBC, or all RAV4 EV, this connects to a short loopback harness instead.
- These connectors are not used in the Toyota RAV4 EV (possibly not used in MB B250e) as it is not provisioned for DCFC and does not have those contactors.
Common Issues
- Two 50A fuses protect the AC input legs: one fuse for Neutral, one for Hot/L1. These fuses are a common failure point. The cause of their failure is not known. Some units have had their fuses fail more than once. Typically, only one fails at a time. The fuses are "semiconductor fuses", special high-speed parts (opposite of "slow-blow") for use with sensitive electronics, and they sometimes have a hybrid diode-and-fuse symbol, though they have no diode function. The OEM fuse is Ferraz Shawmut 50A 500VAC fuse, part No. A50P50-4[11]. Some people have found that after replacing a single failed fuse, the other one will later fail; it is surmised that this is possibly a genuine instance of a fuse weakening over time/use, so the generic recommendation is to replace them both. Typical pricing is USD$50-100 each in 2023.
Charger Dimensions:
- nnnmm x nnnmm x nnnmm
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
