Tesla Model S GEN1 Charger
Tesla GEN1 Onboard AC Charger
Tesla GEN1 Onboard AC Charger. Note the stamped "TESLA" on the cover, which visually distinguishes it from later versions. This view shows the Logic Connector X042/X043
Charger Connectors
Tesla Model S GEN1 OBC Connectors
  • Logic (X042 (or X043, when used in "Slave" mode))
  • AC (Input)
  • DC (Output)
  • Fast Charge (DCFC) Contactors Control (2x)
  • Tesla: In Single OBC vehicles, all connectors are used. This is the most common scenario.
  • Tesla: In Dual OBC vehicles, the second ("Slave") OBC does not utilize the Fast Charge Contactors connectors, as the first ("Master") OBC performs the function.
  • Toyota: The Fast Charge Contactors connectors are not used, as the vehicle is not provisioned for DCFC and therefore there are no Fast Charge Contactors.
Tesla Model S GEN1 OBC X042 Logic Connector pinout.
Telsa Model S (2012-2013) OBC Logic Connector X042 details, from Tesla Service Manual.
Logic Connector X042 (Master charger) and X043 (Slave charger). Molex 19418-0026, female harness connector to mate with X042 Logic Connector on Tesla GEN1 OBC.
Logic Connector X042, Master charger, and X043, Slave charger. Molex 19418-0026, female connector to mate with X042 Logic Connector on Tesla GEN1 OBC.
Molex 19418-0026, female harness-side connector to mate with X042 (male terminals) Logic Connector on Tesla GEN1 OBC (Logic Connector X042 (Master charger) and X043 (Slave charger)). This is the terminals-end view of the housing.
Wire size *
Telsa
Wire Color *
4 CAN + 20 AWG (0.5mm²) RD
6 Fast Charge CAN AKA "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" 20 AWG (0.5mm²) RD-WH
7 12v GND 20 AWG (0.5mm²) BK
8 Drive inhibit "Prox out", signal to DU to inhibit drive 22 AWG (0.35mm²) OR-PU
10 CAN - 20 AWG (0.5mm²) DB
12 "BMS_12V_in" "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables charger?) 18 AWG (0.75mm²) RD-GY
Tesla GEN1 OBC: "Slave" configuration Logic and HVIL connections.
Tesla Model S OBC in Single/Master configuration. Note "parked" harness WWMA2 on Rear HVJB.
AC Input Connector
DC Output Connector
HVIL Connector (J5)
Tesla Model S GEN1 OBC: HVIL and HVJB AC Charging Bypass Contactor Control Connectors
Tesla Model S GEN1 OBC: HVIL and HVJB Fast Charge Contactor Control Connectors
HVIL (J5): Only the outside pins (top and bottom) are in use. These are used to integrate the HVJB's Lid Reed Switch into the HVIL loop. Every OBC contains a 60 ohm resistor in series with its Lid Switch (added to 2014 Wiring Diagram above, included by Tesla in Service Bulletin SB-10052449-4313 below, 2015), between Logic Connector (X042/X043) pin 3 and HVIL connector "top pin".
  • Tesla: Connected to the HVJB's Lid Reed Switch if the OBC is the only (single) or Master (dual) OBC. If the OBC is configured as Second/Slave, a loopback harness is connected instead.
  • Tesla: The loopback harness, Tesla 1101371-00-A, is included/stored inside all Tesla Model S GEN1 Rear HVJB in an internal "parking" socket, when only a single OBC is provisioned.
  • Toyota: A loopback harness is always connected.
  • MB: TBD (probably a loopback harness is connected).
The below two pictures show the GEN1 Rear HVJB's Lid Reed Switch, which had a relatively high failure rate[16] that caused shutdowns, error messages, and start failures:
Tesla Model S GEN1 HVJB (under rear seat), lid removed, showing the HVIL cover reed switch and HVIL connector that connects to a mating connector on the OBC.
Tesla Model S GEN1 Rear HVJB (under rear seat), lid removed, showing the HVIL cover reed switch and HVIL connector that connects to a mating connector on the OBC.
Closeup of Tesla Model S GEN1 HVJB (under rear seat), lid removed, showing the HVIL cover reed switch and HVIL connector that connects to a mating connector on the OBC.
The following two images showcase the "parking" connector on the Rear HVJB for harness WWMA2, which if not connected to a Second/Slave OBC, must be connected to this "parking" connector in order to obtain a 60 ohm resistor to complete the HVIL loop. The BMS maintains a constant current in the HVIL loop, and will not allow the contactors to close (or remain closed) if the correct resistance isn't measured in the HVIL loop[16]. Telsa's various documentation from this era have several inaccuracies when verified against actual vehicles; do not rely upon documented pinouts.
The following two images showcase the "parking" connector on the Rear HVJB for harness WWMA2, which if not connected to a Second/Slave OBC, must be connected to this "parking" connector in order to obtain a 60 ohm resistor to complete the HVIL loop. The BMS maintains a constant current in the HVIL loop, and will not allow the contactors to close (or remain closed) if the correct resistance isn't measured in the HVIL loop[17]. Telsa's various documentation from this era have several inaccuracies when verified against actual vehicles; do not rely upon documented pinouts.
Tesla Model S GEN1 HVIL circuit overview, from Tesla Service Bulletin SB-10052449-4313, pg. 1.
Tesla Model S GEN1 HVIL circuit overview, from Tesla Service Bulletin SB-10052449-4313, pg. 7.
Tesla Model S GEN1 HVIL circuit overview, from Tesla Service Bulletin SB-10052449-4313, pg. 8.
Telsa Model S GEN1 Rear HVJB: harness WWMA2 "parking" connector which contains only a 60 ohm resistor. This connector is used when a Tesla does not have a Second/Slave OBC.
Telsa Model S GEN1 Rear HVJB: front view of harness WWMA2 "parking" connector which contains only a 60 ohm resistor.  This connector is used when a Tesla does not have a Second/Slave OBC.
Telsa Model S GEN1 Rear HVJB: rear views of harness WWMA2 "parking" connector which contains only a 60 ohm resistor.  This connector is used when a Tesla does not have a Second/Slave OBC.
Telsa Model S GEN1 Rear HVJB: rear view of harness WWMA2 "parking" connector which contains only a 60 ohm net resistance.  This connector is used when a Tesla does not have a Second/Slave OBC.
Tesla Model S GEN1 Rear HVJB "parking" connector for harness WWMA2, used in Single OBC installations only. Note (3) 180 ohm resistors, connected in parallel, to obtain net 60 ohms for HVIL loop.
180 ohm resistor. One of three on the Tesla Model S GEN1 Rear HVJB "parking" connector for harness WWMA2, which is used only in Single OBC installations.
Tesla Model S GEN1 OBC HVIL Loopback connector. Used on Tesla Slave OBC installations where the HVJB Lid Reed Switch is already connected to the HVIL circuit via the Master OBC. Also used in RAV4 EV, as there is no HVJB installed at all in those models.
  • The top row pins are 12v; the bottom row pins are Auxiliary contacts, NO (normally open).
  • These connectors are not used in the Toyota RAV4 EV (and possibly not used in MB B250e) as the RAV4 EV is not provisioned for DCFC and does not have those contactors.
Common Issues
  • Two 50A fuses protect the AC input legs: one fuse for Neutral, one for Hot/L1. These fuses are a common failure point. The cause of their failure is not known. Some units have had their fuses fail more than once. Typically, only one fails at a time. The fuses are "semiconductor fuses", special high-speed parts (opposite of "slow-blow") for use with sensitive electronics, and they sometimes have a hybrid diode-and-fuse symbol, though they have no diode function. The OEM fuse is Ferraz Shawmut 50A 500VAC fuse, part No. A50P50-4[18]. Some people have found that after replacing a single failed fuse, the other one will later fail; it is surmised that this is possibly a genuine instance of a fuse weakening over time/use, so the generic recommendation is to replace them both. Typical pricing is USD$50-100 each in 2023.
Important Considerations
Output Voltage Range
Tesla GEN1 OBC label, showing part No. and input/output specs. These are not to be relied upon.
HEED DAMIEN'S WARNING:[19]
Charger Dimensions:
  • 19-13/16" L x 13-7/16" W x 4-7/16" H (503mm L x 341mm W x 113mm H)
  • Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
  • 6009278-00-x
  • 6009354-00-x
Toyota Part Numbers:
  • G9090-0R010 (discontinued)
  • G9090-0R011
MB Part Number(s):
  • TBD
