IPDM56
Getting started with the iPDM56 VCU
Note: all documentation is under https://github.com/celeron55/ipdm56
Connect the board to USB and power it up
This is a sanity check before you start soldering and chase your tail troubleshooting.
Use a good quality micro USB cable and power the board up through it via a charger or computer.
both LEDs are lit after the initial Arduino sketch has started
Solder the connector onto the board
Before you start soldering, test fit the PCB to see if the remaining holes line up with the threaded mounts of the enclosure.
Apart from soldering equipment you will need two small screws and nuts to secure the 56 pin header connector to the PCB so it is secured during soldering.
If you're in a rush, you should alternate between the two sections to avoid overheating the board and reduce stresses on the joints.
Connector PCB screws (borrowed from ATX mainboard mounts)
Connector secured for soldering
Alternating between both sides
all 56 pins soldered
Wiring in the pins
(starting with the USB connection)
Plastic grid removed, note different numbering
Numbering scheme of connector can be different!
Perforate the seal with multimeter probe, put the 4 wires from the USB cable through the grid.
Front view, note different numbering
Square and kerb a chopstick for pushing the crimped pins
Push the pins through
First program - blink LEDs
Set up the Arduino IDE. The ATMega 328 is also used on Arduino UNO, Arduino Pro Mini and Arduino Nano, so programming should be familiar. See https://docs.arduino.cc/hardware/uno-rev3 for some tips.
As the iPDM56 uses a CH340G USB-to-serial converter, the choice of bootloader will be ignored, just choose the correct serial port.
