Talk:CCS32Clara
Jump to navigation
Jump to search
Add: Section on Supported Chargers/Test Results
For Context GitHub Pull Request: https://github.com/uhi22/ccs32clara/pull/4#issue-2045351022
Proposed added Section if PR gets accepted might look something like this:
Supported Chargers
Clara + Focci has been tested successfully at various chargers.
You can find the raw test results documented on GitHub. [will be added soon]
Currently there are no official supported chargers. (This doesn´t mean Clara + Focci) is not working, just that there havent been sufficient tests yet).
Conflicting of use of udcdivider
udcdivider is listed as both:
"Division factor from ADC digits to V of external voltage measurement board"
and
"some dummy item as the important bit is in the Offset field: the version. In this case I signal non-existent CDM version 10."
Can both co-exist?
