Nissan Leaf Gen 3 (2018 up EM57)
Revision as of 13:47, 30 March 2024 by Jrbe (talk | contribs) (→‎SJ8 / J8)
110kw / 160kW
The third generation Nissan leaf stack has both 110kW and 160kW versions. Current understanding is the only difference between these 2 is the Nissan controller board. https://openinverter.org/forum/viewtopic.php?p=45803#p45803
This Open Inverter adapter board replaces the Nissan controller in these gen. 3 inverters. Theory is that either inverter could make at least 160kW with this OI adapter & controller boards if the rest of the system can support it.
This is a work in progress. This board is not yet tested.
Things to verify
  • Let's use strikethrough as we verify these items.
  • The board address needs to be checked with the brake circuit connected and disconnected (cut SJ4 to disconnect, solder to connect it.) Need to verify this does not skew the address voltage and change the address. There are vias to measure the voltage in the board address block to help.
  • Verify different 32 & 40 position connector footprints match up. Through hole footprints are unknown. The SMD connectors work properly.
  • The second part of the brake circuit looks like it should block 2.5v and below from turning on the brake lights. Above about 2.7v the brake lights should go on. This depends on if the STM32 can push enough power to overcome a few components. Trying to give a wider range of available addresses and still have the brake light output trigger in regen. The high side switch turns on at around 1.2v on the enable line, that's what the zener blocking diode is for.
  • R3 and R9 are setup as 0R (jumper) resistors. Nissan has 2 lines for each current sensor signal. These should not be populated for now.
  • R2 & R4 are unclear if they should be grounds and are 0R resistor / jumpers. Need to figure out if these are in fact required grounds.
    • J1 connector (Nissan 32 pos.) on position 20 if using thru hole board to wire connectors it only has a .3mm trace to ground which likely won't last or work well. If this ground is required there is a large ground via right next to position 20 to solder to for a good ground connection. Will need to correct this in the next version once understood.
  • R13 is a pull down resistor for the T_SINK input. This is at 3K3 in V0.0.1 but unsure if this is ideal. V0.0.4 changed this to a 1.2k pull down resistor. There are 2 plated thru holes on each side of R13 to use to make testing the ideal value easier.
  • L2 in rev V0.0.2 had an 0805 inductor rated for only 15ma. Changed to a Sunlord 4030 / AKA 4.0mm X 4.0mm inductor that can pass 700ma +. I don't think any V0.0.2 boards were made yet but not sure.
  • What connector options to use for the Open Inverter connections to get out of the inverter.
  • The capacitors on each contactor mosfet gate should be checked that they do not delay turn on or off too much and that they help eliminate chatter. If they are too large they could run the mosfets in the linear region and could cause damage. Set these to do not populate, not tested.
SJ1
(mini mainboard back) should be **soldered / not soldered.**
SJ3
(mini mainboard) soldered / jumpers to the left is setup for cruise control 12v input. It should stay like this.
Soldered to the right is 3.3v MOSI for SPI communications. Do not apply 12v to this input while shorted to the right of the jumper or damage likely will result.
SJ4
can be ignored. It should stay shorted.
SJ5
- Open Inverter has an Emergency Stop (E-Stop) function to quickly, non-destructively, and safely shut down the inverter. To use the E-Stop option, connect an E-stop switch (closed when OK, open in stop position) that feeds 12v to position 40 of this adapter board. The E-Stop switch must break the 12v signal of the circuit when the e-stop is pressed or if a wire breaks. Other methods are not recommended for safety. This is to guarantee it shuts the inverter down when needed. Starting with V0.0.4 pin 26 of the 40 position connector has a solder jumper to 12v. This allows the user to connect on board +12V to pin 26 to be used as the +12V supply for the E-Stop Switch. See p26 +12V below.
To bypass the E-Stop functionality, solder the SJ5 jumper closed. No need to populate position 40 (e-stop signal) in this bypassed case.
SJ6
is optional and can be left with both positions open. Never short all 3!
Position 19 on the 40 position Nissan connector is a PWM_USER / OUT_TEMP signal. Part of the PWM_USER circuitry is an optional 0805) pull up resistor (R19) that is not populated. An 0805 SMD resistor can be added if a pullup is desired on board (the footprint is for a hand solder 0805, it's larger than normal but makes it easier to modify and hand solder.) SJ6 is a voltage select solder jumper to select between the onboard voltages of 5.3V and 12v to create the wave form / signal on this output. There is also a plated through hole labeled as UV1 (user voltage) that can be used for the pull up with a a different voltage if desired. Do not solder / short SJ6 if UV1 is used.
C11 capacitor is to reduce EMI. If your PWM device needs a very sharp edge this may interfere. C12 is a 1uF capacitor to help stabilize the user selected voltage, covers 5.3, 12v and user voltage selections. To the left of this +12V pad is a plated through hole to supply an unregulated +12v to be used for a user supplied voltage regulator for a different voltage. The n channel mosfet is rated for 100v and 1.5 amps. This is a common footprint with a wide range of voltages and currents up to about 1.5 amps.
SJ8 / J8
are voltage select jumpers. SJ8 is a solder jumper and J8 is a 3 position male pin header. You must use only one style jumper to select 3.3v or 5v for your programmer so you do not accidently short 5.3v and 3.3v together. J8 has 2.54mm pin spacing, common jumper caps will work to select the voltage. See programming the ESP32 below for further info on programming.
SJH1 & SJL1
These should be either both soldered if a 120ohm CAN termination resistor is desired here. If this is the end of a CAN line these should both be soldered. CAN lines should be terminated at each end of the lines with a 120 ohm resistor. Do not leave one solder jumper open & one closed.
p26 +12V
On the 40 position connector there is a solder jumper on the back of the board. This is meant to supply +12V to pin 26 of the 40 position Nissan connector to be used for the E-Stop function if desired (connected to both the SMD and through hole footprints.) There are very thin traces from the solder jumper up to a +12v plated through hole above the MOSI label meant to act as a crude fuse.
IL1 & IL2
Il1 & IL2 are redundant current sensor signal paths. OEMs commonly use 2 signal paths for each current sensor to the inverter controller. Open inverter uses 1 trace for each current sensor, these solder jumpers can be soldered closed to switch to have 2 signal paths to the inverter brain. These can both be left open.
Soldering on the Nissan header connectors
32 position header connector options:
Connector Part # Manufacturer Page Sourcing
Desoldered Nissan ? You desoldering it from the inverter. Possible to get part # from TE?
2322737-1 https://www.te.com/usa-en/product-2322737-1.html https://octopart.com/2322737-1-te+connectivity-141486892?r=sp
2326784-1 https://www.te.com/usa-en/product-2326784-1.html https://octopart.com/2326784-1-te+connectivity+%2F+amp-125203930?r=sp
2326784-2 https://www.te.com/usa-en/product-2326784-2.html https://octopart.com/2326784-2-te+connectivity+%2F+amp-119798073?r=sp
2326784-3 https://www.te.com/usa-en/product-2326784-3.html https://octopart.com/2326784-3-te+connectivity-141486898?r=sp
1318745-4 https://www.te.com/usa-en/product-1318745-4.html https://octopart.com/1318745-4-te+connectivity+%2F+amp-111145194?r=sp
2326784-4 https://www.te.com/usa-en/product-2326784-4.html Not Available?
32 position connector
40 position header connector options:
Desoldered Nissan You desoldering it from the inverter. Possible to get part # from TE?
2322791-1 https://www.te.com/usa-en/product-2322791-1.html https://octopart.com/2322791-1-te+connectivity+%2F+amp-128564844?r=sp
2322791-2 https://www.te.com/usa-en/product-2322791-2.html https://octopart.com/2322791-2-te+connectivity-142686361?r=sp
2322791-3 https://www.te.com/usa-en/product-2322791-3.html https://octopart.com/2322791-3-te+connectivity+%2F+amp-119798059?r=sp
2377920-1 https://www.te.com/usa-en/product-2377920-1.html Not Available?
1-1318384-8 https://www.te.com/usa-en/product-1-1318384-8.html https://octopart.com/1-1318384-8-te+connectivity+%2F+amp-118490360?r=sp
1318384-5 https://www.te.com/usa-en/product-1318384-5.html https://octopart.com/1318384-5-te+connectivity+%2F+amp-111145192?r=sp
40 position Leaf female connector modifications
Delete this old image
40 position connector front V0.0.4
The 40 position female housing has the following known part numbers:
Part # Manufacturer Link Sourcing Found Where?
1318389-1 https://www.te.com/usa-en/product-1318389-1.html https://octopart.com/1318389-1-te+connectivity-42270477?r=sp
2325415-1 https://www.te.com/usa-en/product-2325415-1.html https://octopart.com/search?q=2325415-1&currency=USD&specs=0 Listed as mating with 2322791-1
Terminals for the Nissan connectors
40 position Nissan connector labeled
Terminals (female / receptacle) listed to fit the 1318389-1 are here, https://www.te.com/usa-en/product-CAT-T319-T273.html?q=&d=752372&type=products&compatible=1318389-1&samples=N&inStoreWithoutPL=false&instock=N
Product Description Marketing Part Number Products Terminal Type Mating Tab Width Mating Tab Thickness Terminal Transmits Wire Size Wire Size Sealable Terminal Seal Type Wire Size Search
CONTACT CRIMP SNAP IN 22-20 1-170321-1 1-170321-1 Receptacle 3 mm .65 mm 0 – 24 A (Low Power) 22 – 20 AWG .3 – .5 mm² No .3 mm², .4 mm², .5 mm²
CONTACT SNAP-IN 1-170321-4 1-170321-4 Receptacle 3 mm .65 mm 0 – 24 A (Low Power) 22 – 20 AWG .3 – .5 mm² No .3 mm², .4 mm², .5 mm²
025 REC CONTACT 1123343-1 1123343-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 24 – 20 AWG .22 – .56 mm² No .2 mm², .25 mm², .3 mm², .4 mm², .5 mm²
025 REC CONTACT GOLD FORMING 1123343-2 1123343-2 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 24 – 20 AWG .22 – .56 mm² No .2 mm², .25 mm², .3 mm², .4 mm², .5 mm²
025 REC CONTACT PRETIN L/P CUT 1318143-1 1318143-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 22 – 20 AWG .37 – .56 mm² No .35 mm², .4 mm², .5 mm²
.025 SEALED REC CONT 1318329-1 1318329-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 20 – 18 AWG .5 – .85 mm² No .5 mm², .6 mm², .75 mm²
.040 SEALED REC CONT 1318332-1 1318332-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 18 – 16 AWG .75 – 1.25 mm² No .75 mm², 1 mm², 1.25 mm²
025 IDC REC CONT FORM 1318688-1 1318688-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 22 – 20 AWG .3 – .5 mm² No .3 mm², .4 mm², .5 mm²
025 RCPT IDC TIN (0.08SQ) 1565403-1 1565403-1 Receptacle .64 mm .64 mm 22 – 20 AWG .3 – .5 mm² No .3 mm², .4 mm², .5 mm²
0.64 RCPT SEALED TIN STRIP 1612290-1 1612290-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 24 – 22 AWG .22 – .35 mm² Yes Single Wire Seal (SWS) .2 mm², .25 mm², .3 mm²
0.64 RCPT SEALED AU STRIP 1612290-2 1612290-2 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 24 – 22 AWG .22 – .35 mm² Yes Single Wire Seal (SWS) .2 mm², .25 mm², .3 mm²
REC CONT ASSY S RANGE 025 CLEA 1717148-1 1717148-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 22 – 20 AWG .3 – .5 mm² Yes Family Seal .3 mm², .4 mm², .5 mm²
025 RECEPTACLE CONTACT 1801069-2 1801069-2 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 22 – 20 AWG .37 – .56 mm² No .35 mm², .4 mm², .5 mm²
025 RECEPTACLE CONTACT 1801248-2 1801248-2 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 20 – 18 AWG .5 – .75 mm² No .5 mm², .6 mm², .75 mm²
025 RECEPTACLE CONTACT 2005097-1 2005097-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 26 – 24 AWG .13 – .22 mm² No .13 mm², .15 mm², .2 mm²
0.64 RCPT SEALED TIN STRIP(L SIZE) 2040168-1 2040168-1 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 20 AWG .5 mm² Yes Family Seal .5 mm²
0.64 RCPT SEALED AU STRIP(L SIZE) 2040168-2 2040168-2 Receptacle .64 mm .64 mm 0 – 24 A (Low Power) 20 AWG .5 mm² Yes Family Seal .5 mm²
**add crimper options**
The adapter board is labeled at the 40 position connector to help with wiring up the inverter / harness. Images of these are to the right and a table is below with the positions in order.
The surface mount version of this connector starts with position 21, then 1, 22, 2, etc. The position labeling on the pc board is offset slightly on both sides to help with this.
The pc board renderings / pin labeling images to the right can be used to help populate the connector and wire the vehicle.
Pos. Abbreviation Description AKA Details Pos. Abbreviation Description AKA Details
1 +12VSW Switched +12v 21 +12VSW Switched +12v
2 PRE□ Precharge contactor switched ground 4.5 ampterminal limit?
recommended to use an economizer
22 DCSW□ EV battery contactor switched ground 4.5 ampterminal limit?
3 GND Ground 23 GND Ground
4 GND Ground 24 GND Ground
5 oERR□ Output - Error signal, switched ground 1 amp 25 CRUISE*/MOSI3.3v! Cruise control signal 12v / MOSI 3.3v 12v set as cruise. 3.3v as MOSI
6 sSTRT* Input, 12v start signal pulse 26 empty empty - optional +12v for E-Stop switch
7 sFWD* Input, 12v forward 27 sBRAKE* Brake light input 12v
8 sREV* Input, 12v reverse 28 MTEMP+ Motor temp senor +
9 empty empty 29 sBMS* Battery Management System error +12 signal
10 oBRK▲ Output, brake +12v (see SJ4) 1.5 amps 30 MTEMP- Motor temp sensor -
11 THROT2° Throttle 2, 0-6.6v signal 31 empty empty
12 CANH CAN high signal (see SJH1) 120 ohm termination resistor solder jumpers 32 THROT1° Throttle 1, 0-6.6v signal
13 CANL CAN low signal (see SJL1) 120 ohm termination resistor solder jumpers 33 empty empty
14 oUVTG□ optional output? 1amp max switched ground 1 amp 34 empty empty
15 empty empty 35 S1 Encoder S1 wire
16 S3 Encoder S3 wire 36 empty empty
17 +5V +5V for sensors (like throttle) 37 S4 Encoder S4 wire
18 S2 Encoder S2 wire 38 +5V +5V for sensors (like throttle)
19 oTEMP□ over temp signal, switched ground, 1 amp max 1 amp, has EMI filter capacitor (C11) for PWM 39 R2 Encoder R2 wire
20 R1 Encoder R1 wire 40 sE-STOP Optional Emergency stop switch (see SJ5) Can add an E-Stop switch to 12v.
KEY
* = 12v Signal
° - 0-6.6v Signal
□ = Switched ground
▲ = Switched +12v
A visual pin numbering of the 40 position connector.
ESP32 with associated headers and 3.3v capacitor
ESP32 programming header
J4 is used to program the ESP32.
There is a slot above the labels 38 and J4 for a zip tie hole to hold an antenna wire. This can be used if a u.FL antenna is used along with an ESP32-S2-Wroom-I module.
Position Description
1 IO0
2 GND
3 GND
4 +3.3v / +5V, (J8 / JP8)
5 ESP32 USART_RX
6 ESP32 USART_TX
Note that the enable line is broken out on the other side of the ESP32 if needed.
R25 and C13 are for boot delay to assist programming.
Programming the STM32
Currently the recommendation is to program the ESP32 first, then the STM32.
**settings info** link..
**Editing the IP address if using multiple motors.**
**options** link..
Extra header J3
J3 gives access to TX & RX lines to the STM32 along with 3.3v and ground if the ESP32 is not populated. J3 is labeled from the ESP32.
C19 is an unpopulated handsolder 0805 capacitor footprint if this optional header is used and 3.3V power dips. There is also an unpopulated 10x10.5 aluminum capacitor footprint at C20 to assist even more if needed.
1 +3.3v
2 GND
3 STM32 USART_TX
4 STM32 USART_RX
5 empty
6 empty
7 empty
8 empty
9 empty
10 empty
Contactor outputs, PRE & DCSW
**4.5 amps max (header terminal limited?, otherwise 10-17A max to be determined with testing.)**
**add economizer circuit if not included in contactor**
**100nF capacitors on each gate to help eliminate chatter. Required? Need to change? Contactor chatter issues?** too much will make the mosfet stay in the linear region for a while, could damage them.
Brake output
There is a high side switch soldered on the board that outputs +12v @ 1.5A maximum when regen is active. This is likely not enough to drive brake lights directly. It is up to the user to combine the vehicles brake switch output with this brake output +12v signal. Consider an automotive SSR with the vehicles normal brake output feed through a diode along with the inverter brake output through a diode so either or both turn on the SSR.
