MG CCS Charge Port
Revision as of 10:03, 16 August 2024 by WillK (talk | contribs)
MG Charge Port Part Numbers
Part Number Description Comments
11011337 MG 5 2022 Charge Port DC Max 200A, 750V; AC 32A, 250V
MG5 Charge Port
The MG5 uses a combined Type 2 - CCS2 charge port. The charge port is of fairly basic design.
The HV cables exit sideways to give a reasonably slimline (<120mm) profile
Charge port locking is implemented with the usual 12V actuator, polarity of wires is reversed to unlock. There is a manual pull cable override.
There are 4 temperature sensors, one each of +ve and -ve pins for AC (Type2) and DC (CCS) connections.
The sensors are of NTC type, esitmated to be NTC100K - measured resistance 107kOhm at room temp.[1]
The are no LEDs for lighting nor charge status indications.
Printing on the port specifies DC Max 200A, 750V; AC 32A, 250V. This is consistent with the MG5s max. charging speed of 80kw (400V).
MG Charge Port
MG Charge Port
Connectors
  • Low Volatge : 18-pin Sumitomo 6188-5910 [2] (6188-5911 to mate)
  • AC : 4-in Yonggui YGC1174-EV-S - Unobtainium? (YGC1174-EV-P to mate)
  • DC HV : Spade/M8 type connector.
Pin Out
Low Volatge Connector
Pin Wire Colour Description
1 Red Charge Port Motor Lock+
2 Black Charge Port Motor Lock-
3 Green Charge Port Lock feedback - connects to pin 4 when locked.
4 Yellow Charge Port Lock feedback - connects to pin 3 when locked.
5 Red PP ProximityPilot
6 Red Temp sensor Type2 AC +ve Pin temp (pair with pin 7) NTC100k
7 Red Temp sensor Type2 AC +ve Pin temp (pair with pin 6) NTC100k
8 Black Temp sensor Type2 AC -ve Pin temp (pair with pin 9) NTC100k
9 Black Temp sensor Type2 AC -ve Pin temp (pair with pin 8) NTC100k
10 Brown CP ControlPilot
11 Green AC Earth
12 - Not populated
13 - Not populated
14 - Not populated
15 Red Temp sensor CCS +ve Pin temp (pair with pin 16) NTC100k
16 Red Temp sensor CCS +ve Pin temp (pair with pin 15) NTC100k
17 Black Temp sensor CCS -ve Pin temp (pair with pin 18) NTC100k
18 Black Temp sensor CCS -ve Pin temp (pair with pin 17) NTC100k
