Nissan Leaf inverter
Revision as of 20:57, 31 August 2024 by Arber333 (talk | contribs)
  • Nissan Leaf Gen1 inverter
Damien has presented his controler here: https://github.com/damienmaguire/Nissan-Leaf-Inverter-Controller PDF file with connector pinout: https://openinverter.org/forum/download/file.php?id=839
  • Nissan Leaf Gen2 inverter
Regarding the Gen2 inverter connector that used to be unobtainable can in fact be bought. https://openinverter.org/wiki/File:Prius_Gen3_-_Auris_-_Yaris_Connector_Body_.jpg The housing can be bought from Toyota, cost was 89 SEK (~€8)! Then terminals and wire seals are needed and after some web searching and testing I have concluded this BOM: https://openinverter.org/forum/download/file.php?id=32637&mode=view Connector housing: Toyota G9260-47010, 36p Toyota G9266-47010, 13p
Small terminal, 0.64: 0,22-0,35mm2 TE 1612290-1 (tested ok) Sumitomo 8100-3455 Small wire seal: Sumitomo 7165-1198 Small blind plug: Sumitomo 7165-0797
Large terminal, 2.3: 0,3-0,5mm2 Yazaki 7116-4025 (tested ok) Sumitomo 8100-0460 0,8-1,25mm2 Yazaki 7116-4026 Sumitomo 8100-0461 2,0mm2 Sumitomo 8100-0462 Large wire seal: Sumitomo 7165-0342 D4,9mm d1,4-2,0mm Sumitomo 7165-0343 D4,9mm d2,0-2,5mm Sumitomo 7165-0344 D4,9mm d2,5-2,9mm Large blind plug: Sumitomo 7161-9787 D4,7mm
Terminal extraction tool 0.64 Terminals : Sumitomo 3070000 or 307-0000-03 2.3II Terminals : Precision screwdriver(1.2mm~1.6mm)
NOTE: The Sumitomo terminals are not tested but thay look the same as the ones I have tested and documents point to the Sumitomo extraction tool, hence my guess is they will fit as well.
  • Nissan Leaf Gen3 inverter
Regarding the Gen3 inverter connector that used to be unobtainable can in fact be bought. https://openinverter.org/wiki/File:Prius_Gen3_-_Auris_-_Yaris_Connector_Body_.jpg The housing can be bought from Toyota, cost was 89 SEK (~€8)! Then terminals and wire seals are needed and after some web searching and testing I have concluded this BOM: https://openinverter.org/forum/download/file.php?id=32637&mode=view Connector housing: Toyota G9260-47010, 36p Toyota G9266-47010, 13p
