Bosch Accelerator pedal position sensor
Revision as of 09:26, 8 September 2024 by J0hannes (talk | contribs)
General Information
Bosch PWG-3 from a Honda Jazz
The trade name for this sensor is Bosch PWG-3, this is quite ubiquitous and used by several manufacturers over decades
In the early days of electronic diesel control, many cars were adapted to use e-throttle sensors from the standard cable throttle pedal, as the gasoline versions were still using cable throttle. Being that Bosch ECU's powered a lot of these cars its not surprising to find a bosch sensor to do what you need. Of course it makes sense to find one thats common in your region. [1]
The voltage from both sensors ramps linearly from the fully released position to the fully depressed position[2]. The pedal should be supplied with a reasonable stable and accurate 5V supply to ensure a proper readout.
Voltage Output of Throttle Sensors
Pedal Position Sensor 1 Sensor 2
Fully Released 2,47 V 0,56 V
Fully Depressed 3,74 V 1,92 V
Versions
The colors and pinout of wiring varies depending on manufacturer.
PWG-3 sensor end cap removed, from a BWM 3 E46
When looking for a dual potentiometer sensor, be sure to obtain a SIX-wire sensor. There are variants of this with five wires, they have only ONE potentiometer and a position switch. This list is non-exhaustive, but demonstrates the availability of the sensor
Selected Versions
Part Number Cars Used In Electrical Connector Side
0 281 002 484 For Honda Jazz 2002-2008
0 205 001 012
  • Volkswagen Passat B4 (year of construction 1994-1996)
  • Volkswagen LT II (year of construction 1996-2006)
0 281 002 286
  • Volkswagen Passat B5 (year of construction 1997-2000)
  • Audi A6, S6 (year of construction 1997-2005)
0 205 001 040
  • BMW 3 Compact (E36) (Year of Construction 03.1994 - 08.2000)
  • BMW 3 Saloon (E36) (Year of Construction 09.1990 - 02.1998)
  • BMW 5 Touring (E34) (Year of Construction 11.1991 - 01.1997)
  • BMW 5 Saloon (E34) (Year of Construction 12.1987 - 11.1995)
  • BMW 7 (E38) (Year of Construction 10.1994 - 11.2001)
  • BMW 3 Touring (E36) (Year of Construction 01.1995 - 10.1999)
  • BMW 5 Saloon (E39) (Year of Construction 09.1995 - 06.2003)
  • BMW 5 Touring (E39) (Year of Construction 09.1996 - 05.2004)
  • BMW 3 Saloon (E46) (Year of Construction 02.1998 - 04.2005)
0 205 001 206
  • MAN L 2000 (Year of Construction 10.1993 - ...)
  • MAN M 2000 L (Year of Construction 08.1995 - ...)
  • MAN F 2000 (Year of Construction 01.1994 - ...)
  • MAN M 90 (Year of Construction 08.1988 - 06.1996)
  • MAN F 90 (Year of Construction 07.1986 - ...)
  • MAN M 2000 M (Year of Construction 08.1995 - ...)
  • MAN F 90 Unterflur (Year of Construction 07.1986 - 05.1994)
  • MAN E 2000 (Year of Construction 05.2000 - ...)
0 281 002 370
  • ROVER 45 Hatchback (RT) (Year of Construction 02.2000 - 05.2005)
  • ROVER 25 Hatchback (RF) (Year of Construction 09.1999 - 06.2006)
  • ROVER 45 Saloon (RT) (Year of Construction 02.2000 - 05.2005)
  • ROVER Commerce Box Body / Hatchback (RF) (Year of Construction 01.2003 - 12.2005)
  • MG MG ZR Hatchback (Year of Construction 06.2001 - 04.2005)
  • MG ZS Saloon (Year of Construction 07.2001 - 04.2005)
  • MG MG ZS Hatchback (Year of Construction 07.2001 - 10.2005)
