16-cell BMS
16-cell BMS
The boards can be bought in the shop.
Flashing firmware
If like me you have sourced the BMS boards from an alternative source then you will need to flash the bootloader and firmware onto the BMS. This is a relatively straightforward process once understood but took me a while to get it to work.
Firstly you will need an STLink dongle, I used this one [2] but I believe any will do.
I used STM32CubeProgrammer [3] on Linux to flash my board and also (prior to flashing) upgrade the STLinkdongle to the latest firmware (might not be necessary but felt it was wise to do so).
Once you've got STM32Cubeprogrammer installed you're probably best erasing the STM32 Chip to ensure you're starting from a clean board. Navigate to the "Erasing & Programming" tab on the left and connect to your STlink dongle (if you havent already). Once connected, (you can also update the firmware on the dongle at this point on the "Memory & File Editing" tab), connect the dongle to the BMS board via the VDCG pins...
(V = Voltage 3.3V, D = SWDIO, C = SWCLK, G = Gnd)
and perform a "full chip erase".
Once thats complete head over to Github to download the Bootloader [4] and download the hex file (you may need to be logged in to download the files).
Once downloaded, in STM32CubeProgrammer, navigate to the "Memory & File Editing" tab and open the hex file you just downloaded, once opened you can use the "Download" button to flash the bootloader to your BMS board.
You can now repeat the above process of opening the hex file and "downloading" to the BMS board for the main BMS firmware which is available from the BMS Github repository [5] .
Once all that is done, you can move onto the Web interface. You'll need the "Can Backend" version of the ESP32 Web Interface available here [6] (click the green code button and download zip)
Once downloaded download Arduino IDE 1.8.19 (you'll need this version, nothing beyond version 2 as this does not support SPIFFS flashing as far as I'm aware) and set it up for flashing to ESP32 boards [7] and also flashing ESP32 Spiffs [8].
To setup the Web interface Arduino sketch, you'll want to unzip and (IMPORTANT) RENAME the folder to "esp32-web-interface" to match the ino file within the folder, if you don't do this you'll have problems further down the line. Once unzipped and renamed, open the esp32-web-interface.ino sketch file and upload it to your ESP32 dev board. when this completed you'll also need to upload the SPIFFS image, you can do this by going to Tools and "ESP32 Sketch Data Upload" and choosing SPIFFS. once this is complete, you can connect your ESP32 to your BMS board via CAN and power them and they shuld work (note you'll need the 12V enable in line connected also).
Once on the Web interface, select Node ID 10 and a speed of 500kbps and you'll have all your wonderful BMS spot values and params ready to go.
Communication
All configuration, queries and firmware updates are done via the CAN bus. There is no independent web interface like known from e.g. the inverter. However there is a solution to connect an ESP32 via CAN and then have the known web interface [9] or you can use Dave Fiddes "oic" tool for the command line[10]. It is important to know that the main module has node-id 10 and the subsequent ones 10+i (i index of submodule, so 1st submodule has node-id 1). The base node id can be configured to start at something else than 10.
Apart from that the modules output periodic CAN messages depending on their role. The base address for cyclic messages defaults to 0x1F4 and can be changed by modifying pdobase on the main module. pdobase is ignored on the sub modules.
All modules output on ID 501 (0x1F5) + i
start length item description
0 13 umin minimum cell voltage of module i
16 13 umax maximum cell voltage of module i
30 2 counter counts from 0-3 (anti-freeze)
32 13 uavg average cell voltage of module i
48 8 tempmin Minimum temp +40 on module i
56 8 tempmax Maximum temp +40 on module i
In addition the main module outputs on id 500 (0x1F4)
0 11 chargelim maximum charge current in A
11 11 dischargelim maximum discharge current in A
22 10 soc Pack soc in 0.1%
32 16 idcavg Averaged current reading of last 1s in 0.1A - signed!
48 10 utotal Total pack voltage in V
62 2 counter counts from 0-3 (anti-freeze)
Reading individual cell voltages
Cell voltages are only available via CAN SDO from the module that measures them. So voltages 1-16 must be queried from the first (main) module, 17-32 from the 2nd (1st submodule) and so on. With Dave Fiddes tool this translates to:
oic -n 10 dumpall #dumps all values including cell voltages from 1st module
oic -n 11 dumpall #same for second module
oic -n 11 read u0 #Read first cell voltage of second module
For querying voltages say in your arduino sketch you'll need to acquire every voltage separately by sending and receiving SDO messages
0x60A#0x40 idhigh 0x21 idlow 0 0 0 0
0x60A#0x40 0x07 0x21 0xD6 0 0 0 0
0x58A#0x43 0x07 0x21 0xD6 0xD0 0xED 0x01 0
The next cell would be on 0x7D7 and the last on 0x7E5. The next 16 voltages are then queried from node id 0x60B.
Configuration Parameters
There is currently a limited set of parameters which will be extended as the software grows. This table always reflects the latest git commit. Check the page history for previous versions.
These are the parameters of v0.16.B
BMS
gain uV/dig 1 1000 586 Scaling factor from ADC digits to mV
correction0 ppm -10000 10000 -1250 The first two and the last channel have slightly different topology and need their own correction factor
correction1 ppm -10000 10000 1500
correction15 ppm -10000 10000 1000
numchan 1 16 16 Number of cells connected to the module
balmode 0 3 0 Balancing mode
0=No balancing 1=Only bump up low cells 2=Only dissipate high cells 3=Do both
ubalance mV 0 4500 4500 Voltage above which top balancing is started
idlewait s 0 100000 60 Number of seconds to wait after stop of current flow to measure unloaded cell voltage und start balancing
Battery Characteristics
dischargemax A 1 2047 200 Maximum discharge current
nomcap Ah 0 1000 100 Nominal capacity
icc1 A 1 2000 50 Maximum charge current of empty battery
icc2 A 1 2000 30 Maximum charge current of roughly half-charged battery
icc3 A 1 2000 20 Maximum charge current of rather full battery
ucv1 mV 3000 4500 3900 First constant voltage set point. Transition to next one when dropping below icc2
ucv2 mV 3000 4500 4000 Second constant voltage set point. Transition to next one when dropping below icc3
ucellmax mV 3000 4500 4200 Third constant voltage set point and maximum cell voltage
ucellmin mV 1000 4500 3300 Minimum loaded cell voltage. Discharge limit is dropped to stay above this value
chargeXsoc % 0 100 Percentage of charge current at soc X. In between two points charge current is interpolated
Sensor Setup
idcgain dig/A -1000 1000 10 Gain (or actually division factor) of current sensor
idcofs dig -4095 4095 0 0A offset
idcmode 0 3 0 Current sensor mode 0=Off, 1=Single Ended ADC, 2=Differential ADC, 3=ISA current shunt
tempsns -1 3 -1 Temperature sensor -1=Off, 0=JCurve, 1=KTY81, 2=PT1000, 3=LeafBMS
Communication
pdobase 0 2047 500 base COB Id for cyclic messages. Main module uses pdobase and pdobase+1, 1st submodule uses pdobase+2 and so on
sdobase 0 63 10 base node ID for SDO queries. Main module uses sdobase, 1st submodule sdobase+1 and so on
Operation
Calculating current limits
Charge Curve
The initial approach was to assign a certain charge current to points in the SoC curve. This method can be skewed if the SoC calculation is off for some reason. The new method deploys 3 CC/CV regulators. This was copied from oberving VWs charge curve of the MEB cars. The first regulator has the highest charge current and aims for a voltage typically around 3.9V for many NMC chemistries. When current drops below the CC value of the second regulator then that one is used, aiming for a higher voltage of typically 4V. And finally the 3rd regulator takes over aiming for the charge end voltage of typically 4.2V. When setting all 3 to the same values a simple CC/CV curve is generated.
Voltage limits
Voltage limits are enforced via a P-regulator. I.e. as we approach the upper or lower voltage limit current is cut back to stay away from the limits until it reaches 0A. The upper and lower limit is configurable
Temperature limits
These are not enforced yet. High temperature will cut back both charge and discharge current whereas low temperature will only cut back charge current.
Energy limits
Operating Limits
  • Max voltage for the board is 70v
  • Max number of cells is 16
