Tesla Large Drive Control Board
I'm new to the forum. Interested in converting a 750 and looking to use a Tesla Large Drive. I'm looking for the control board to buy
- Has thanked: 382 times
- Been thanked: 1574 times
Re: Tesla Large Drive Control Board
You will find this board in the openinverter shop starting middle of June.
Thanks. I was able to the files
Regarding the board build. I'm getting not that from the BOM i have to source three items myself. Is this normal. No issue with finding them myself soldering them. I'm just interested in knowing if this is normal.
The LDU does not rotate when the throttle is engaged and then shows OVERCURRENT lasterr. There are no errors when ignition is turned on or when the start button is pressed. The motor shows that it’s in RUN mode, but when the throttle is engaged we get the OVERCURRENT error.
Elektro-Funken RSR/#P85DPorsche.
Youtube video:
https://www.youtube.com/watch?v=fHaCl6OBNRQ&app=desktop
Youtube video:
You keep posting about the same error but you never follow the instructions given nor give rich context. Has it worked before? What are the parameters? Are you sure all IGBT banks are ok?
