Gen 2 Charger V5 Software Development Thread
bulletbug
Re: Gen 2 Charger V5 Software Development Thread
Post by bulletbug »
Bryson wrote: Sun May 24, 2020 1:09 am
bulletbug wrote: Sun May 24, 2020 12:32 am I think I've got one of the odd gen 2 chargers with something different going on.
What rev is your charger, for the record?
If by Rev. you mean the charger itself, I don't know. The label was damaged on arrival. If there's another way to find out that answer...I'm all ears.
If by rev you mean Damien's board...I'm using the version 4 board.
Bryson
Post by Bryson »
Bummer. I highly doubt there are hardware variances within part number + revs on the Tesla side so it would be interesting to isolate which ones are most compatible with the replacement board and which ones have issues. I’d bet a small sum that there’sa common denominator here
Kevin Sharpe
Been thanked: 9 times
Post by Kevin Sharpe »
Bryson wrote: Sun May 24, 2020 5:27 am I’d bet a small sum that there’sa common denominator here
Unfortunately we have lots different Gen 2 hardware (and presumably firmware) versions in circulation. We also have 'master' and 'slave' configurations to contend with.
What we really need is a list in the wiki of known working configurations. I'll try to make a start on the chargers in the workshop in a couple of months. For now maybe people with working systems could document them :)
Bryson
Post by Bryson »
I’ll buy mine blind, cross my fingers, then reply whether it works nicely or not :)
Kevin Sharpe
Bryson wrote: Sun May 24, 2020 2:44 pm I’ll buy mine blind, cross my fingers, then reply whether it works nicely or not :)
If possible buy from a vendor with a returns policy so that you can return it if it fails your tests.
bulletbug
Post by bulletbug »
Bryson wrote: Sun May 24, 2020 5:27 am Bummer. I highly doubt there are hardware variances within part number + revs on the Tesla side so it would be interesting to isolate which ones are most compatible with the replacement board and which ones have issues. I’d bet a small sum that there’sa common denominator here
I have some ideas related to my situation that i've posted in this thread. My board mfg. company didn't install the c30 capacitor part of the reset switch circuit. They said the capacitor kept oxidizing. I was under the impression that it was only related to the physical reset button, so I've gone on without it, thinking I could power cycle the board to reset it. I don't think that is true, now. Check out my other post for the super-long-winded explanation of the idea. I'll be testing it later today -
viewtopic.php?f=10&t=78&p=11445#p11445
Kevin Sharpe
bulletbug wrote: Sun May 24, 2020 3:07 pm
V5 boards use a different CPU... lets try and keep this thread focused on V5 :)
jon volk
Post by jon volk »
Kevin Sharpe wrote: Sun May 24, 2020 2:48 pm
Sounds like a market for bootleg void stickers
jon volk
Post by jon volk »
I haven’t done much lately since my sledgehammer fix for a static environment is working for me. I’ll be working on this more and established a Github account for sharing. Nothing has been uploaded yet, but be sure to bookmark if you like letting smoke out.
https://github.com/jonvolk
jon volk
Post by jon volk »
Now we’re cooking.
nabilriaz
Post by nabilriaz »
HI Jon,
Can we download the software from you Github account, I am new to this, but I did but Gen 2 V5 board from Damien, I wan to start testing.
do we need to upload this software in the board ? do we use Linux to do that ? I have USB to Serial Cable
I will never give up
jon volk
Post by jon volk »
You'll need to upload the .elf or .bin file in the Debug folder with an ST-link. Same procedure as shown here.
With the file I have uploaded, you'll need an EVSE capable of at least 40 amps. Otherwise, youll need to make configuration files. The board from Damian should already have some version of software to familiarize yourself with how it all works.
nabilriaz
Post by nabilriaz »
Thanks Jon, do you think this adaptor would work, I have Tesla HPC , so i dont need to buy EVSE
https://www.amazon.ca/Tesla-Adaptateur- ... 44&sr=8-39
jon volk
Post by jon volk »
I havent messed with any Tesla to J1772 adapters at this point so I cant really comment.
Bryson
Post by Bryson »
Got my v5a board in (thank you Damien), soldered it up, and programmed/installed the ESP8266. I've noticed that on power cycling the board, none of my settings are sticking, it resets to defaults on every power cycle (power cycle via USB plug/unplug, I am not connected to a charger). I'm doing the 'q' quit to save to memory step, same process as Tom's simpBMS.
I'm still pretty new to embedded, although I can ham my way into the code to begin debugging, but I was wondering if anyone else is having the same issue before I go for it.
Default settings it returns to:
1 - Auto Enable : ON
2 - Modules Enabled : 123
3 - Can Mode : Master
4 - Port Type : 1
5 - Phase Wiring : 1
6 - DC Charge Voltage : 400.000000 0V
7 - AC Current Limit : 13A
8 - CAN0 Speed : 500.000031 0
a - Can Debug : OFF
b - EVSE Debug : ON
t - termination voltage : 400.000000 0V
q - To Quit Menu
Along with serial message:
Proximity Status : Unconnected /ADC Raw: 1023 AC limit : 0 /Cable Limit: 0 /Module Cur Request: 0 /DC total Cur:0.00 /DC Setpoint:400 /DC tVolt:400 /DC driven AC Cur Lim: 5000
24751 State: 0 Phases : 0 Modules Avtive : 0 OFF D1 L
Modules Turned OFF
jon volk
Post by jon volk »
The serial menu setting changes won’t retain for me either after a power reset. I only use it to debug and once I was happy with the settings, would just update the parameters in the code. I don’t know if that was intended behavior, but I don’t have any problems with that.
Has thanked: 75 times
Been thanked: 696 times
It is supposed to save
nesto1972
Post by nesto1972 »
Good morning
I having problem with serial monitor or uart cable.I got no debug info.
i connect black-GND,orange-RX,yellow-TX,it open the monitor window (also in PuTTY)and stays empty.
baud is 115200
what can i do?
jon volk
Post by jon volk »
Try swapping rx and tx
nesto1972
Post by nesto1972 »
Tryed! not better!!!
jon volk
Post by jon volk »
Was this after uploading code? If so, youll need to hit the reset button on the board or cycle power.
nesto1972
Post by nesto1972 »
Its a tested board of Damien!
I no longer provide built and tested boards. It is a kit and is not a final product as stated on the webshop :
"BETA RELEASE FOR DEVELOPERS ONLY! DO NOT PURCHASE THIS IF YOU ARE NOT PREPARED / ABLE TO ASSIST WITH TESTING AND DEVELOPMENT! NOT A FINAL PRODUCT!!!"
1)You should have 2 red leds on the board.
2)You need to use a 3v3 level ftdi NOT a 5v level.
3)I have only tested with arduino serial monitor so give that a try.
I did load both boards with Jon's latest code and tested serial comms.
nesto1972
Post by nesto1972 »
Sorry i took the wrong word!My english language is limited so it can happen like this.
I think i have the right cable ordered.
Will also try another computer and the second board!
If you see a wrong setting pls. let me know...:)
That all looks good. You should be seeing something on the serial monitor ...
