Regen issue
Peter
Been thanked: 9 times
Regen issue
Post by Peter »
Hello Forum. Looking for some advice here please. I have set up basic trial regen parameters (I am using a Combi V8 board driven inverter) and try a basic regen with motor off load I can see the braking effect and reverse current but then I have to power down and restart the inverter to be able to run again, any clues please ?
Parameters..
Brake pedal pressed
Regen pot set at 0v or 5v makes no difference (need to sort pot use later)
pot2min 4095
pot2max 4095
SingleRegen set
brknompedal -30
brkpedalramp 5
brknom 0
brkmax 0
brkrampstr 10
brkout -10
Thanks in advance for any suggestions. Peter
Has thanked: 384 times
Been thanked: 1589 times
Re: Regen issue
Why do you have to power down and restart? What happens otherwise?
Peter
Re: Regen issue
Post by Peter »
Hello Johannes. Thank you for your reply. The inverter will not allow the motor to run again unless I power down and restart.
Peter
Re: Regen issue
Post by Peter »
Hi Johannes. Just as a reminder I am using Revision 1. Peter
joromy
Re: Regen issue
Post by joromy »
Peter wrote: Thu Jun 11, 2020 4:52 pm Hello Forum. Looking for some advice here please. I have set up basic trial regen parameters (I am using a Combi V8 board driven inverter) and try a basic regen with motor off load I can see the braking effect and reverse current but then I have to power down and restart the inverter to be able to run again, any clues please ?
Please give us some more info, like fault messages.
Does is restart without regen?
Do you use the web interface?
Peter
Re: Regen issue
Post by Peter »
Hi Joromy. I do use the web interface, I am copying the spot values etc to post on the forum later.
Peter
Re: Regen issue
Post by Peter »
Hi again Johannes. I am using 4.59 software, would it be better to use the latest now as you have made so may improvements ?
joromy
Re: Regen issue
Post by joromy »
What do you get if you click the "Display Error Memory" button, after start and when the inverter is not starting again
Re: Regen issue
Peter wrote: Sat Jun 13, 2020 3:47 pm Hi again Johannes. I am using 4.59 software, would it be better to use the latest now as you have made so may improvements ?
You can always try as you can just downgrade if you run into issues.
I have no idea what changes I made since.
Peter
Re: Regen issue
Post by Peter »
Hi Johannes. My apologies the software is listed as 4.87 on the spot values. Peter
Peter
Re: Regen issue
Post by Peter »
Have attached spot value and parameter files. Thanks in advance for all your help.
Spot Values trying regen.txt
(580 Bytes) Downloaded 161 times
CombiV8 Settings.txt
(1.02 KiB) Downloaded 152 times
Re: Regen issue
Can you set fmin to 0.3 and try again?
Peter
Re: Regen issue
Post by Peter »
Hi Johannes. Will try and report back, fingers crossed :-) Thanks. Peter
Peter
Re: Regen issue
Post by Peter »
Hi Johannes. Has anyone ever told you that you are a genius ?? If not may I be the first to say so :-)
My next task is to use the regen pot to control how much regen when brake pedal pressed.
Re: Regen issue
Good to hear :)
I think I'm gonna delete that fmin parameter and hard code it to a very low value. It's caused a lot of trouble.
Isaac96
Re: Regen issue
Post by Isaac96 »
johu wrote: Thu Jun 18, 2020 7:41 pm Good to hear :)
I agree, it especially causes problems with low min slip settings. Are there any possible problems from setting it too low?
-Isaac
Re: Regen issue
Isaac96 wrote: Thu Jun 18, 2020 9:16 pm I agree, it especially causes problems with low min slip settings. Are there any possible problems from setting it too low?
-Isaac
No the only goal is to have a 0 amplitude criteria. I guess I'll hard-code 0.2Hz
