chain or belt
john
chain or belt
Post by john »
has anyone had experience of belt driven and chain driven speed reduction, I wonder which is best for my EV conversion, any help appreciated
bundao
Re: chain or belt
Post by bundao »
I tried using Gates Polychain Carbon belts but I found them just too noisy.
I considered making a silent chain replacement or perhaps a gearbox (transmission chain couldn't manage the speeds I needed).
But I have since come by a cheap Leaf motor and transmission, so I'm going to try that instead.
LRBen
Has thanked: 122 times
Been thanked: 290 times
Re: chain or belt
Post by LRBen »
I used a chain on my quadbike conversion, I think I would have prefered a belt but I had limited space. The chain is more durable in terms of stones and dirt getting thrown up into it as well.
Whats your project? Not sure I would use a belt or chain on anything bigger than a quad bike.
john
Re: chain or belt
Post by john »
bundao wrote: Wed Jun 24, 2020 10:44 am I tried using Gates Polychain Carbon belts but I found them just too noisy.
thanks, but your energy requirement are way above mine, I only need 8 to 10kw for my vintage car
john
Re: chain or belt
Post by john »
LRBen wrote: Thu Jun 25, 2020 10:13 am I used a chain on my quadbike conversion, I think I would have prefered a belt but I had limited space. The chain is more durable in terms of stones and dirt getting thrown up into it as well.
my project is an EV conversion of my vintage Ford T, only needs 8 to 10 kw of power,
LRBen
Re: chain or belt
Post by LRBen »
Either system has it's own pros and cons. I would say either would work unless there are some constraints that prevent you using one of them, like space restrictions prevented me using belts.
Have a look at the pros and cons of each and see which you would prefer.
