Locked
bobby_come_lately
Has thanked: 41 times
Been thanked: 40 times
Post by bobby_come_lately »
Jack Bauer wrote: Sun Jun 28, 2020 9:11 am yep thats it.
Thank you.
Now only problem is that I don't seem to be able to log in to the wiki. Username and password works fine for the forum but not for wiki. And when I try to reset on the wiki says the username/email isn't recognised. Weird.
Has thanked: 409 times
Been thanked: 261 times
Post by MattsAwesomeStuff »
Different account for forum and wiki I believe. Treat them like separate websites meshed.
I think.
bobby_come_lately
MattsAwesomeStuff wrote: Mon Jun 29, 2020 12:44 am Different account for forum and wiki I believe. Treat them like separate websites meshed.
I think.
OK - thanks. Will try re-registering. But all the instructions I can find say your forum username and password should work on the wiki.
EDIT: there's no way to register directly on the Wiki. Have messaged @johu for help.
bobby_come_lately wrote: Mon Jun 29, 2020 11:37 amOK - thanks. Will try re-registering. But all the instructions I can find say your forum username and password should work on the wiki.
Oops. My bad then.
konstantin8818
Been thanked: 10 times
Post by konstantin8818 »
As soon as I've decided to buy the board, shop become unavailable :| and now I'm itchy :cry:
Has thanked: 12 times
Been thanked: 356 times
What are you trying to buy? Shop seems fine.
konstantin8818
Jack Bauer wrote: Tue Jun 30, 2020 7:04 pm What are you trying to buy? Shop seems fine.
Cheap version of V1c board.
It works thrue VPN, but I don't trust VPN when it comes to payments and shops
Even Microsoft Edge can't open it. Today in the morning it was available... I just can't get it.
Huh. Weird. Working ok for me. Can someone else confirm? Anyway, here's a thought : I have a complete v1c that starred in my exploding inverter episode. it's fine except for a little smoke damage. Can't sell it, dont really need it so how about I donate it to you:)
LRBen
Has thanked: 78 times
Been thanked: 230 times
Post by LRBen »
Jack Bauer wrote: Tue Jun 30, 2020 7:30 pmCan someone else confirm?
Shop works fine for me as well,
konstantin8818
Jack Bauer wrote: Tue Jun 30, 2020 7:30 pm Huh. Weird. Working ok for me. Can someone else confirm? Anyway, here's a thought : I have a complete v1c that starred in my exploding inverter episode. it's fine except for a little smoke damage. Can't sell it, dont really need it so how about I donate it to you:)
:D Smoked board for smoked inverter - win win situation. I'll definately buy normal one, but if you insist, I'll take it :mrgreen: . Will whait untill tomorrow, maybe shop become available.
Now this is wierd: I can get to the shop thrue my smartphone. I've even reboot my PC but it can't open shop :?
konstantin8818
Ordered via smartphone :)
Thanks for the order.
konstantin8818
Jack Bauer wrote: Wed Jul 01, 2020 5:50 am Thanks for the order.
Today shop works fine...
If you really don't need that smoked board, I'll happily trade it for donation or patreon support ;)
Bacause I'm not shure if those salvaged connectors will do the trick...
Product of three hours of soldering iron misery:
White connector turn out to be really heat resistive, otherwise it wouldn't make it :mrgreen:
Box of goodies on its way to you tomorrow.
konstantin8818
Jack Bauer wrote: Wed Jul 01, 2020 2:09 pm Box of goodies on its way to you tomorrow.
Much appreciated! Now i'm itchy even more... :D
Double posting this here from my E39 build thread just in case :
Bit more driving around this morning in the E39. Did a few acceleratoins with measured 70kw on the battery side. No problems. Got one desat event when I tried to be a hero and pull away in 4th. Restarted and drove away in 3rd. Looking very promising so far.
bobby_come_lately
Very cool.
Progress on my side - of a sort. Finally got that 10k swapped for the 8K2 and now have a much healthier -4.81 on the -5V supply...but udc is still waving around all over the place!
Time to start stripping down inverter number 2...
Has thanked: 83 times
Been thanked: 431 times
I've swapped the resistor over.
My UDC plot is below. ~0.5v difference
bobby_come_lately
Baffled and a bit fed up right now. Could really use some help trouble shooting.
Stripped down the new inverter, installed the board in it, and udc still all over the place - with udcgain set at 6.12 and 33.6V coming in, it's reading anywhere from 23 to 180 V.
So it doesn't look like the inverter is the issue.
But I've now confirmed a solid -5v supply and checked the path from the 50-pin connector to the ADC that reads udc. 50-pin connector has been checked under a microscope and any bad connections fixed.
I'm giving up for today. Will come back to it tomorrow. But any suggestions in the mean time for what I might try next would be very welcome. Convinced I'm doing something stupid but clueless as to what it might be.
When testing is the lid on the inverter and all the bolts for the capacitor done up tight?
bobby_come_lately
Yep. Doubting myself so just went around and checked it all again - that's the two on the opposite end from the AMPSEAL connector and the one next to the two battery terminals that you can access from the outside. Plus the two battery connectors obviously.
I'm other side of the Pennines if you want to try your board in my inverter or my board in yours.
invokeperformance
Post by invokeperformance »
Damien if you haven't donated the smoked board already. I would love to have it for my gen 3 Prius inverter as it would help me get my project off the ground and in return i would gladly do a pateron donation and pay for shipping.
@konstantin8818
@jack Bauer
bobby_come_lately
Bigpie wrote: Thu Jul 02, 2020 3:38 pm I'm other side of the Pennines if you want to try your board in my inverter or my board in yours.
Thank you. May take you up on that soon if I can't make some progress this weekend.
invokeperformance
konstantin8818 wrote: Wed Jul 01, 2020 4:38 pm
@konstantin8818
@jack Bauer
Locked
