Gen 2 Charger V5 Software Development Thread
- Been thanked: 4 times
Re: Gen 2 Charger V5 Software Development Thread
Thank you much!
Great! I’ll give it a shot later tonight.
Good news and not so good news:
Good: Saving to EEPROM is working now!
Not so good: It looks like WiFi commands may be sending to the wrong serial output. Here are a couple serial logs from the USB connector, and a shot of my WiFi. In this case the board is powered up from USB and not from an external 12V source, nothing else connected other than the USB cable.
Also, I can't set 7 - AC Current Limit to anything above 43A. I'm running a 48A EVSE and 48A Tesla charger on a 50A mains circuit and would like to give it the full 48
- Has thanked: 9 times
- Been thanked: 282 times
WiFi data is only sent during charging. I'll check out the current limit.
Just to be clear I personally tested the listed functions in the E39 before publishing the binaries.
Thank you. It looks like it overflows at 44A: 44A -> 0A, 45 -> 1A, 46 -> 2A, 47 -> 3A,...
Is it intentional that the WiFi data is also being transmitted over the USB serial? That’s what I’m assuming I’m seeing with “va000,vb000...”? If it’s sending zeros already, why not show zeros when not charging instead of 900s?
It also clutters the serial display to have it sent to USB serial, probably better to not transmit it there.
I have updated the binary on Github to remove the wifi data from the serial monitor. Yes it was placed there on purpose to allow me verify the wifi was representing the correct data. I accept the point about display clutter for normal users hence the updated binary.
Folks, I gave every opportunity for people to get involved with the software. Heck I pleaded. But at the end of the day it needed doing so I went out and employed someone to do the work. Due to that fact I am not at this time releasing the sources for free. So if anyone doesnt like the way the software works there are 3 options :
1)code your own using the base version that is freely available on Github. (free)
2)support me on patreon to obtain the source. ($100)
3)wait for the source to be released. (free)
If I do find any bugs and / or make updates then the binary on github will be updated.(free)
Thank you again, I hope this isn’t being taken as an offense.
Happy to contribute a chunk to patreon, but would prefer an option for a one-time contribution, which I didn’t see as an option. I can’t speak for others, but they may be in similar boats, particularly due to the state of the economy (not your problem, I know).
In any case, thank you again
- Kevin Sharpe
- Been thanked: 8 times
Just sign up for the $100 tier on patreon and then cancel after a month if you don't think the software is worth more. You may not realise that the noise you generate with these questions is amplified 100 fold by others. I can guarantee that we will lose access to Damien if we don't get smarter about how we 'use' him.
We have cancelled six courses this year which has a profound impact on Damien's income. Please think before you moan about the cost of access to the source code.
Oof, apologies. We’re all in this together.
- Bassmobile
- Has thanked: 7 times
Say, we need one of those Children's Miracle Network style commercials for Damien.
For just $3.33 a day you too can support a struggling Open Source developer in a foreign country..
But seriously. $100 / month is a steal for what Damien is contributing to this community and the world. We need more blokes to pony up and put down the cash to support all of his awesome work.
- Boxster EV
- Has thanked: 56 times
- Been thanked: 48 times
Following this process makes programming the chip a piece of cake (Thanks Jon). The .hex file taken from Damien's Github (Thanks Damien).
Quick vid of me doing just that:
Although it was correctly highlighted here that I'm testing with a crappy piece of 13 amp cable, initial tests are positive and the charger is now drawing AC current for about 10 seconds before shutting down for undervoltage (due to said test cable). I'll continue with AC and EVSE integration into the car and report back accordingly.
if you go into the menu and select ac current limit at 2 or 3 amps it might keep running.
- Boxster EV
Yep, it’s working a treat.Jack Bauer wrote: ↑Thu Sep 10, 2020 2:06 pm if you go into the menu and select ac current limit at 2 or 3 amps it might keep running.
- EV-OLUTION
Hi. Just registered for this forum as I got some questions related to Gen 2 with V5 controller. Hope someone can give advice on that. I have just bought Gen 2 Tesla onboard charger and going to install it on my LEAF(2011) as a secondary onboard charger. The questions are following:
Do I need contactors on HV side after Tesla charger? So they would disconnect charger from HV side while vehicle is in Drive mode and only would connect when charging is activated. Or can I leave it connected permanently?
I watched Damiens videos of him playing with Gen2 charger, and he mentions that AC side connection must be done at particular timing. Does this still apply to V5? In main code I can see this comment about AC contactor control: "This mode also control HVDC via digital out 1 and AC mains via a contactor via Digital out 2.-Working". But in V5 diagram I can't see any outputs with labels Digital Out 1 or Out 2.
I am thinking of controlling charger either by wire activation, or CAN control as it will be working in a slave mode. Where can I find more data of how to control it by sending particular CAN messages? I could only find the following information: 0x42C, 0x43C and 0x44 for setting current and 0x45C for setting voltage. But I guess this is not what I should send to STM32. I guess these messages are sent by STM32 to Tesla charger modules. I will try to have a look at the code later and see if I can figure it out myself. But any kind of info related to control by CAN will be much appreciated.
I will also try to put all V5 code to Arduino IDE. I successfully done this with other STM32 based projects, hopefully this won't be much more complicated. This makes it easier for people who are already familiar with Arduino programming like myself.
Just use the new firmware :
viewtopic.php?f=10&t=1323
- EV-OLUTION
Thanks Jack (Damien?)! I didn't realized there is a commercial firmware and wiki related to it. By reading wiki info I got all answers to my questions
