Tesla Model 3 Battery Hacking
- Kevin Sharpe
- Been thanked: 8 times
Re: Tesla Model 3 Battery Hacking
- Has thanked: 11 times
- Been thanked: 344 times
Yeah I'll rig up the Teensy to send some requests and log the responses. Should be interesting.
Well given my programming skills I'm probably asking it for elons favorite breakfast cereal but we get :
from this program which I think is sending request 0x47 :
6E9F
CE9F
DC9F
29DD
EB
9FE5
9FDC
9F35
86FF
6E9F
CE9F
DC9F
29DD
EB
9FE5
9FDC
9F35
86FF
6E9F
CE9F
DC9F
29DD
EB
9FE5
9FDC
9F35
86FF
6E9F
CE9F
DC9F
29DD
EB
// inslude the SPI library:
#include <SPI.h>
#define SS 10
uint16_t send1=0x2ad4;
uint16_t send2=0x0000;
uint16_t req47_a=0x4700;
uint16_t req47_b=0x7000;
uint16_t padding=0x0000;
uint16_t receive1=0;
uint16_t receive2=0;
byte count1=0;
byte count2=0;
void setup() {
// put your setup code here, to run once:
SPI.begin();
pinMode(SS,OUTPUT); //select pin
SerialUSB.begin(115200);//normal port
void loop() {
for(count1=0; count1<=8; count1++)
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE3));//1mhz clock,msb first, mode 3
digitalWrite (SS, LOW); // assert Slave Select
receive1 = SPI.transfer16(send1); // do a transfer
receive2 = SPI.transfer16(send2); // do a transfer
//if (receive2!=65535) SerialUSB.println(receive2,HEX);
digitalWrite (SS, HIGH); // de-assert Slave Select
SPI.endTransaction (); // transaction over
delayMicroseconds(20);
receive1 = SPI.transfer16(req47_a); // do a transfer
receive2 = SPI.transfer16(req47_b); // do a transfer
for(count2=0; count2<=36; count2++)
receive1 = SPI.transfer16(padding); // do a transfer
if (receive1!=0xffff) SerialUSB.println(receive1,HEX);
delayMicroseconds(35);
0x47 Request:
6E9F
CE9F
DC9F
29DD
EB
9FE5
9FDC
9F35
86FF
0x48 Request:
FC9F
D39F
FB9F
2E03
D8
9FCD
9FEA
9F19
8BFF
0x49 Request:
DE9F
F09F
7C9F
2E80
D9
9FD9
9FDE
9F30
5FF
0x4A Request:
A0
FA9F
84A0
14DC
8C
9FE7
9FED
9F38
83FF
0x4B Request:
0x4C Request:
200
A481
ECD
2
C5
7703
3EFF
0x47 Request:
6E9F
CE9F
DC9F
29DD
EB
9FE5
9FDC
9F35
86FF
0x48 Request:
FC9F
D39F
FB9F
2E03
D8
9FCD
9FEA
9F19
8BFF
0x49 Request:
DE9F
F09F
7C9F
2E80
D9
9FD9
9FDE
9F30
5FF
0x4A Request:
A0
FA9F
84A0
14DC
8C
9FE7
9FED
9F38
83FF
0x4B Request:
0x4C Request:
200
A481
ECD
2
C5
7703
3EFF
#include <SPI.h>
#define SS 10
uint16_t req48_a=0x4800;
uint16_t req48_b=0x3400;
uint16_t req49_a=0x4900;
uint16_t req49_b=0xdd00;
uint16_t req4a_a=0x4a00;
uint16_t req4a_b=0xc900;
uint16_t req4b_a=0x4b00;
uint16_t req4b_b=0x2000;
uint16_t req4c_a=0x4c00;
uint16_t req4c_b=0xe100;
uint16_t Request_A=0x0000;
uint16_t Request_B=0x0000;
byte count1=0;
byte count2=0;
void setup() {
SPI.begin();
void loop() {
StartUP();
Request_A=req47_a;
Request_B=req47_b;
SerialUSB.println("0x47 Request:");
GetData();
StartUP();
Request_A=req48_a;
Request_B=req48_b;
SerialUSB.println("0x48 Request:");
GetData();
StartUP();
Request_A=req49_a;
Request_B=req49_b;
SerialUSB.println("0x49 Request:");
GetData();
StartUP();
Request_A=req4a_a;
Request_B=req4a_b;
SerialUSB.println("0x4A Request:");
GetData();
StartUP();
Request_A=req4b_b;
Request_B=req4b_b;
SerialUSB.println("0x4B Request:");
GetData();
StartUP();
Request_A=req4c_a;
Request_B=req4c_b;
SerialUSB.println("0x4C Request:");
GetData();
void GetData()
receive1 = SPI.transfer16(Request_A); // do a transfer
receive2 = SPI.transfer16(Request_B); // do a transfer
delay(75);
void StartUP()
receive1 = SPI.transfer16(0x4f00); // do a transfer
receive2 = SPI.transfer16(0x5f00); // do a transfer
Given the amount of emails and other contacts over the past few days it seems we have quite a few lurkers on this thread. Don't be shy. Join up and help.
and just to remind quite a few of those people as to why we don't just use an LTC6820 :
In this previous video I explain the difference between Tesla ISO-SPI and commercial LTC chips :
- Kevin Sharpe
Please do not contact Damien directly... I've seen his email inbox and it's crazy... the only sustainable way of maintaining this development is through this forumJack Bauer wrote: ↑Thu Aug 06, 2020 11:29 am Given the amount of emails and other contacts over the past few days it seems we have quite a few lurkers on this thread. Don't be shy. Join up and help.
- Has thanked: 207 times
- Been thanked: 570 times
Mind creating a capture of this? I will then smash some code together, first just standalone to get voltages and such then possibly port it into SimpBMS.Jack Bauer wrote: ↑Thu Aug 06, 2020 10:22 am Well given my programming skills I'm probably asking it for elons favorite breakfast cereal but we get :
from this program which I think is sending request 0x47 :Code: Select all
6E9F CE9F DC9F 29DD EB 9FE5 9FDC 9F35 86FF 6E9F CE9F DC9F 29DD EB 9FE5 9FDC 9F35 86FF 6E9F CE9F DC9F 29DD EB 9FE5 9FDC 9F35 86FF 6E9F CE9F DC9F 29DD EB
// inslude the SPI library: #include <SPI.h> #define SS 10 uint16_t send1=0x2ad4; uint16_t send2=0x0000; uint16_t req47_a=0x4700; uint16_t req47_b=0x7000; uint16_t padding=0x0000; uint16_t receive1=0; uint16_t receive2=0; byte count1=0; byte count2=0; void setup() { // put your setup code here, to run once: SPI.begin(); pinMode(SS,OUTPUT); //select pin SerialUSB.begin(115200);//normal port } void loop() { for(count1=0; count1<=8; count1++) { SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE3));//1mhz clock,msb first, mode 3 digitalWrite (SS, LOW); // assert Slave Select receive1 = SPI.transfer16(send1); // do a transfer receive2 = SPI.transfer16(send2); // do a transfer //if (receive2!=65535) SerialUSB.println(receive2,HEX); digitalWrite (SS, HIGH); // de-assert Slave Select SPI.endTransaction (); // transaction over delayMicroseconds(20); } SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE3));//1mhz clock,msb first, mode 3 digitalWrite (SS, LOW); // assert Slave Select receive1 = SPI.transfer16(req47_a); // do a transfer receive2 = SPI.transfer16(req47_b); // do a transfer for(count2=0; count2<=36; count2++) { receive1 = SPI.transfer16(padding); // do a transfer if (receive1!=0xffff) SerialUSB.println(receive1,HEX); } digitalWrite (SS, HIGH); // de-assert Slave Select SPI.endTransaction (); // transaction over delayMicroseconds(35); }
Yep will do. Made a few changes and seem to be getting more data :
0x48 Request:
FC9F
D39F
FB9F
2E03
D8
9FCD
9FEA
9F19
8BFF
0x49 Request:
DE9F
F09F
7C9F
2E80
D9
9FD9
9FDE
9F30
5FF
0x4A Request:
A0
FA9F
84A0
14DC
8C
9FE7
9FED
9F38
83FF
0x4B Request:
0x4C Request:
200
A481
ECD
2
C5
7703
3EFF
0x4D Request:
0x4E Request:
0x4F Request:
0x50 Request:
0x47 Request:
6E9F
CE9F
DC9F
29DD
EB
9FE5
9FDC
9F35
86FF
0x48 Request:
FC9F
D39F
FB9F
2E03
D8
9FCD
9FEA
9F19
8BFF
0x49 Request:
DE9F
F09F
7C9F
2E80
D9
9FD9
9FDE
9F30
5FF
0x4A Request:
A0
FA9F
84A0
14DC
8C
9FE7
9FED
9F38
83FF
0x4B Request:
0x4C Request:
200
A481
ECD
2
C5
7703
3EFF
0x4D Request:
0x4E Request:
0x4F Request:
0x50 Request:
0x47 Request:
6E9F
CE9F
DC9F
29DD
EB
9FE5
9FDC
9F35
86FF
0x48 Request:
#include <SPI.h>
#define SS 10
uint16_t send3=0x21f2;
uint16_t send4=0x4d00;
uint16_t send5=0x0008;
uint16_t sendX=0x0000;
uint16_t sendY=0x0000;
uint16_t req4d_a=0x0100;
uint16_t req4d_b=0x2700;
uint16_t req4e_a=0x0100;
uint16_t req4e_b=0x3300;
uint16_t req4f_a=0x0100;
uint16_t req4f_b=0xda00;
uint16_t req50_a=0x0000;
uint16_t req50_b=0x9400;
byte count1=0;
byte count2=0;
void setup() {
SPI.begin();
void loop() {
StartUP();
sendX=0x21f2;
sendY=0x4d00;
Generic_Send_Once();
sendX=0x0800;
sendY=0x0000;
sendX=0x2ad4;
sendY=0x4d00;
sendX=0x0800;
sendY=0x0000;
Request_A=req47_a;
Request_B=req47_b;
GetData();
StartUP();
Request_A=req48_a;
Request_B=req48_b;
GetData();
StartUP();
Request_A=req49_a;
Request_B=req49_b;
GetData();
StartUP();
Request_A=req4a_a;
Request_B=req4a_b;
GetData();
StartUP();
Request_A=req4b_b;
Request_B=req4b_b;
GetData();
StartUP();
Request_A=req4c_a;
Request_B=req4c_b;
GetData();
StartUP();
Request_A=req4d_a;
Request_B=req4d_b;
SerialUSB.println("0x4D Request:");
GetData();
StartUP();
Request_A=req4e_a;
Request_B=req4e_b;
SerialUSB.println("0x4E Request:");
GetData();
StartUP();
Request_A=req4f_a;
Request_B=req4f_b;
SerialUSB.println("0x4F Request:");
GetData();
StartUP();
Request_A=req50_a;
Request_B=req50_b;
SerialUSB.println("0x50 Request:");
GetData();
void GetData()
//SerialUSB.println(receive1,HEX);
delay(75);
void StartUP()
for(count1=0; count1<=4; count1++)
void Generic_Send_Once()
receive1 = SPI.transfer16(sendX); // do a transfer
receive2 = SPI.transfer16(sendY); // do a transfer
Captures and code now up on the repo :
https://github.com/damienmaguire/Tesla- ... nsy_Master
Have a go with this code: https://github.com/tomdebree/Tesla-Mode ... t_1tdb.ino
'd' should toggle debugging and SPI dump on and off. let me know if it works, also mind capturing the SPI traffic it generates.
Wish I knew how to help but programming and EE are unfortunately not my forte; so please accept the humble funds I sent to your patreon instead. Really inspired by the collaboration and excited by the progress, guys!
Right so from that code we get :
and with debug on :
Capture up on the github :
0x47 Request:
0x48 Request:
0x49 Request:
0x4A Request:
0x4B Request:
0x4C Request:
0x4D Request:
0x4E Request:
0x4F Request:
0x50 Request:
Module 1 : | 4231mV| 4231mV| 0mV| 4334mV| 4334mV| 0mV| 4927mV| 4927mV| 0mV| 5132mV| 5132mV| 0mV| 12mV| 12mV
Module 2 : | 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV
0x47 Request:
0x48 Request:
0x49 Request:
0x4A Request:
0x4B Request:
0x4C Request:
0x4D Request:
0x4E Request:
0x4F Request:
0x50 Request:
and with debug on :
0x48 Request:
FC9F
D39F
FB9F
2E03
D8
9FCD
9FEA
9F19
8BFF
0x49 Request:
DE9F
F09F
7C9F
2E80
D9
9FD9
9FDE
9F30
5FF
0x4A Request:
A0
FA9F
84A0
14DC
8C
9FE7
9FED
9F38
83FF
0x4B Request:
509F
0
200
2B9E
0
2
2
24
A2FF
0x4C Request:
200
A481
ECD
2
C5
7703
3EFF
0x4D Request:
Stupid me, arrays start at o and not 1.
New code for testing, now ever improved to try and populate both of the ICs.
Code online now: https://github.com/tomdebree/Tesla-Mode ... _Test_1tdb
You sir are a steely eyed bms man:)
IC 1 : | 3265mV| 3265mV| 3265mV| 3276mV| 3276mV| 3276mV| 3274mV| 3274mV| 3274mV| 3276mV| 3276mV| 3276mV| 3262mV| 3262mV
IC 2 : | 3275mV| 3275mV| 3275mV| 3273mV| 3273mV| 3273mV| 3273mV| 3273mV| 3273mV| 3267mV| 3267mV| 3267mV| 0mV| 0mV
We don't seem to be reading changes in voltage for some reason. I bet we are missing a "read cells" command somewhere but yeah, fantastic progress Tom:)
Did you also notice my other rookie mistake.
Read in the first voltage, but the second run of the 'FOR' statement do the samething again, dammit.
Now once again updated. Which voltages are you varying? They might have been excluded do to my mistake.
- muehlpower
- Has thanked: 14 times
- Been thanked: 141 times
it doesn't have to be " g <= 14" for usb printing to see the last value?
Dammit, yes that mistake remained. If we get confirmation of the voltages working we can move on, otherwise we got to dig to find out why the voltages are not updating.muehlpower wrote: ↑Fri Aug 07, 2020 6:51 pm it doesn't have to be " g <= 14" for usb printing to see the last value?
Latest code is sort of acting weird :
0x50 Request:
IC 1 : | 3258mV| 3268mV| 3269mV| 4158mV| 184mV| 3187mV| 3453mV| 299mV| 5240mV| 0mV| 0mV| 0mV| 0mV| 0mV
IC 2 : | 3270mV| 3270mV| 3269mV| 1476mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV| 0mV
3265
3265
0x47 Request:
0x48 Request:
0x49 Request:
0x4A Request:
0x4B Request:
0x4C Request:
0x4D Request:
0x4E Request:
0x4F Request:
0x50 Request:
3265
3265
0x50 Request:
3265
3265
0x47 Request:
0x48 Request:
0x49 Request:
0x4A Request:
0x4B Request:
0x4C Request:
0x4D Request:
0x4E Request:
0x4F Request:
0x50 Request:
3265
3265
Video update though a little out of date already:)
Please run it with debug on, I need to check the moving of certain bytes.
Shit found it, was a messy mistake on my part. was using variables in multiple places and not accounting for it.
Code online
Good news is we are getting voltages :
IC 1 : | 3258mV| 3268mV| 3269mV| 3315mV| 3269mV| 3271mV| 3269mV| 3270mV| 3264mV| 3272mV| 3271mV| 3278mV| 3260mV| 0mV| 0mV
IC 2 : | 3270mV| 3270mV| 3269mV| 3277mV| 3268mV| 3270mV| 3269mV| 3269mV| 3269mV| 3264mV| 3270mV| 3270mV| 0mV| 0mV| 0mV
3265
3265
Bad news is they don't seem to want to update. I reckon we are missing a command somewhere.
3265
3265
found a command
Now added into the loop. And its online for testing.
0x2BFB
Still no updates sadly :
IC 1 : | 3258mV| 3266mV| 3269mV| 3283mV| 3268mV| 3271mV| 3269mV| 3270mV| 3301mV| 3278mV| 3271mV| 3276mV| 3259mV| 0mV| 0mV
IC 2 : | 3342mV| 3269mV| 3268mV| 3271mV| 3268mV| 3270mV| 3269mV| 3268mV| 3269mV| 3264mV| 3269mV| 3270mV| 0mV| 0mV| 0mV
0x47 Request:
179F
7B9F
A39F
5F2
3D
A3A8
9F9E
9F2D
5FFF
17
9F
7B
9F
A3
9F
3D
A3
A8
9F
9E
9F
0x48 Request:
0x47 Request:
179F
7B9F
A39F
5F2
3D
A3A8
9F9E
9F2D
5FFF
17
9F
7B
9F
A3
9F
3D
A3
A8
9F
9E
9F
0x48 Request:
Okay, so have shuffled some of the SPI frames to match the logs better.
It seems like the slaves need to be told to log the voltages / measure. Can you please provide a capture with the latest software version.
