- Has thanked: 12 times
- Been thanked: 350 times
Ok I'm an idiot. Just had to set il gains and ocur lim to negative and we have full closed loop control:)
Muhahahah.....hahah......waahhhhahahahahah
- Has thanked: 58 times
- Been thanked: 14 times
Good work and great news!
What happened with the oil choice?
Is there a good choice or just random choice?
I have a gallon of Dexron 6 waiting.
At this time I have decided to do a full opensource release of all design sources:)
More updates and video to following including testing in a M3 front DU.
https://github.com/damienmaguire/Tesla- ... Drive-Unit
Rear drive unit now responding to throttle commands in both directions with regen.
To Do :
Secure mod wires.
Button up the inverter
360v full test.
Make install video showing every step (super boring) in a front DU
Run front DU
Retire to Lanzarote on the profits.
To Do :
Secure mod wires.
360v full test.
Run front DU
Great!
Front DU is induction IIRC, does that make for easier tuning and probably easier integration into vehicles?
Does it matter what type of wiring to use between modboard and M3 inverter PCB ?
Min/max. gauge? Insulation thickness?
Or do we just us some leftovers from a computer power supply etc.
I'm using kynar wire most commonly used for wire wrap boards. E.g. :
https://www.digikey.com/catalog/en/part ... eries/1966
I'll go through all this in the forthcoming installation video.
- mdrobnak
- Been thanked: 5 times
The motorsports industry generally uses wire with ETFE (Teflon) / Tefzel wiring. It allows the jacket to be thinner, saving weight. Also highly resistant to things like fuel, etc. Apparently also used in spacecraft - https://en.wikipedia.org/wiki/ETFE
-Matt
-Matt
Thank you both for replies
I found full rolls of kynar wire and thats a bit much.
Maybe I didn't look too hard.
For ETFE I found this item that ships per foot...:
https://www.mouser.fi/ProductDetail/TE- ... YKmg%3D%3D
+200°C max temp and 600V rating, seems ok to me?
Unless a Damien board ships with a string of wire..
Thoughts?
Thoughts?
I may decide to offer a kit with wire. Will see what happens once sales start.
Finding the last few signals today before hv testing.
- EV_Builder
- Been thanked: 37 times
Damien wouldn't it be nicer to un-solder the IC and solder a board with connector to the board?
Or maybe just a legged board with connector? long enough that you can solder the pin to the old IC pad?
Did you consider this? or do we need every other pin pulled-up anyway?
Yes I did indeed think of that at the outset. There were problems with that approach however. That said I am working on a neater solution:)
Oil pump controller used in both front and rear drive units is an Onsemi LV8907.
https://www.onsemi.com/products/power-m ... Session=-1
Scratched an itch and tried Jtaging the Musk brain. Imagine my surprise when it didn't work. Oh well, better give up and go home ....
Attached pinout (as best as I could make anyway) of the 10 pin Jtag port.
Well, the old horse for the long road i suppose. Started a spreadsheet for the pin map on the main MCU :
https://github.com/damienmaguire/Tesla- ... PinMap.ods
For the new idea and neater solution, even though its a "secret" surprise.
Does it require better tools to install compared to modboard..?
With luck it will be quite easy. I know I'm not updating much on here but it is happening at a good pace.
I am putting the motor in my summer car and it is just starting to snow, building car in cold garage, so no rush, wpuld propably go install motor in coldest winter months anyways for snow testing the car If its done
Well, things usually progress quicker without questions and “you’re doing it wrongs”Jack Bauer wrote: ↑Fri Nov 20, 2020 5:47 pm With luck it will be quite easy. I know I'm not updating much on here but it is happening at a good pace.
Yep its moving along well now. I'd say another week and I'll have an announcement:)
Now i am connecting the clues
thumbs up!
- Has thanked: 380 times
- Been thanked: 1571 times
Hmm, relaying the signals to an openinverter processor via SPI?
I promise I haven't spoken to Mr. Bauer
- EV_Builder
Can you tell me those problems?Jack Bauer wrote: ↑Thu Nov 12, 2020 2:56 pm Yes I did indeed think of that at the outset. There were problems with that approach however. That said I am working on a neater solution:)
I hope to have a video out in the next week that will answer all. Still neck deep in it:)
