hello all,
any one can tell me with wich soft and hard i could start to learn and understand CAN protocol ?
i usualy work on rs232, wiegan, modbus, but never on can.
Can beginning
- Peter
- Been thanked: 9 times
Re: Can beginning
Would like a quick demo on how to use the CAN area of the parameters please Johannes if you would be so kind
Re: Can beginning
I picked up CANAble https://canable.io it is based on open-source http://cantact.io
CANAble is a bit pricey but you don't need to waste time building one yourself.
You can build your own:
Hardware: https://github.com/linklayer/cantact-hw
Software: https://github.com/linklayer/cantact-app
- Has thanked: 381 times
- Been thanked: 1571 times
Re: Can beginning
Maybe this helps:
I use a CANDue that Damien donated to me and the software SavvyCAN.
http://store.evtv.me/proddetail.php?pro ... oduecanbus
That CANAble looks very good!
There is a lot of very expensive (500€+) CAN hardware out there that doesn't provide any benefits to the hobby user. So don't spend too much.
Re: Can beginning
I have a cantact with the candlelight firmware. I've not had much of a play with it yet though.
https://github.com/linklayer/candleLight_fw
Re: Can beginning
I am also just starting to explore CANBus.
Does CAN transmits only happen in working start mode? or at any time? I have it on a bench with nothing attached to the board.
If I want to "debug/test" Canable in sniff mode. Will Hardware v3.0 be able to dump some info for me?
I get nothing. Pointers and examples needed.
ex:
ex:
can tx udc 123 0 16 10
