Leaf PDM replacement  [SOLVED]
Microtonicwave
Post by Microtonicwave »
Howdy y’all, I swapped out the PDM on a 13 Leaf because it was not charging and now the car wont charge or drive. It was a brand new PDM from Nissan and there were two things I had to swap over from the old one but do you guys know of anything else that has to be swapped from the old one to the new one?
Right now the codes are:
C118C
P3176
P311C
C1A6E
C1A70
any help would be greatly appreciated :)
paaa
Been thanked: 13 times
Re: Leaf PDM replacement
Post by paaa »
I previously swapped a pdm from one car to another( one had 6kw charger). It just worked fine after the swap. I would imagine you have some other issue, did car previously fast charge?
celeron55
Has thanked: 38 times
Been thanked: 136 times
Post by celeron55 »
Frankly, around here we like to swap the rest of the Leaf out just to keep the motor stack. https://mynissanleaf.com/ seems like a better forum for that list of trouble codes.
