First is the ignition switch - I'm building my car from an empty shell so it has no ignition so I was just going to use a push button start - The stupid question is does the need to be an open or closed connection? either it's pushed for a closed connection and keep everything on , push it again and it's now an open connection and everything is off. OR is this a push connection, it makes contact then opens - everything starts, push it again, makes contact everything is off?
Next stupid question is what is this stop L switch for - Is this just tied to your break pedal and when pushed it activates regen? as it looks like it just lets 12v pass through to activate that signal. To round things up with my final stupid question
