In my conversion, I'm using KiloVac EV200 contactors to isolate the battery terminals. These can of course be opened just by cutting power to the energising coil. I will be wiring the coils via a standard "crash sensor" switch like you find on modern vehicles to provide some impact safety.
My question is this: would you
1) also wire the contactor coils directly through this kill switch, or
2) use the switch as an input to the VCU (leaving control of the contactors to software).
I quite like the idea of running the coils through this switch, as it gives an ultimate "emergency off" if something bad happens. On the other hand, it is possible to accidentally operate the switch while riding. Or some idiot might operate the switch while it's on charge.
What are the dangers of killing the battery connection while the motor is spinning? Might the inverter destroy itself? What about while charging? Would it be better to have a "hidden" kill switch instead?
I know KiloVacs don't take kindly to interrupting current and I've heard that Bad Things Happen with spinning motors and unpowered inverters...
