Wanted Siemens Motor
HI looking for a Siemens Motor around 120 Hp for a speed boat conversion.
Thanks Colm.
Thanks Colm.
- Bratitude
- Has thanked: 180 times
- Been thanked: 374 times
Re: Wanted Siemens Motor
Where are you located?
Hi, I live in Ballina, Co. Tipperary, Ireland on the shores of Lough Derg. What type of motor do you have?
Cheers Colm.
Cheers Colm.
- Bratitude
Welp. I’m in Canada, about to pickup 2 semiens 1pv motors from the ev Ford rangers from back in the day.
What kw are they? just at the planning stage, I want the boat to plane so need good size motor, I was thinking of 120 Kw. Any ideas on this.
Thanks Colm.
Thanks Colm.
- Bratitude
the inverter you choose will determine the power output. But these motors I think can handle 200kw pushed threw them before heat soakColm Spain wrote: ↑Sat Dec 26, 2020 12:08 pm What kw are they? just at the planning stage, I want the boat to plane so need good size motor, I was thinking of 120 Kw. Any ideas on this.
Thanks Colm.
Are you selling one, what price and model no. is it. what inverter would yo recommend.
Thanks Colm.
Thanks Colm.
- Bratitude
I’m in Canada, so not sure if worth it to ship.
It’s the classic Siemens ev motor 1PV5133.
I have a gen 3 Prius inverter I’m going to use to drive one.
Hi , what price are you looking for the motor and I can check out shipping cost.
Many thanks Colm.
Many thanks Colm.
- Bratitude
Looking for 900 Canadian,Colm Spain wrote: ↑Mon Jan 04, 2021 9:18 pm Hi , what price are you looking for the motor and I can check out shipping cost.
Many thanks Colm.
they weight about 200lbs.
And it has a reduction gear box still on it.
Hi, the price seems fine , as you said the carriage might be expensive, will check it out, do you know the difference between 1PV5133 and 1PV5135 motors.
Thanks Colm.
Thanks Colm.
- Bratitude
From my understanding the face plate, shaft and bearings are different. As it’s built around the gear box. Other than that they are identical.Colm Spain wrote: ↑Sun Jan 17, 2021 6:59 pm Hi, the price seems fine , as you said the carriage might be expensive, will check it out, do you know the difference between 1PV5133 and 1PV5135 motors.
Thanks Colm.
There’s quite a bit of miss information on these Siemens motors. power ratting, etc.
But the motor may actually weight around 140lbs
Use without the gear box just requires swapping to sealed bearings.
