Tough BMS
- Has thanked: 166 times
- Been thanked: 413 times
Tough BMS
I have used another distributed BMS for a long time now. Surprisingly i had absolutely NO issues with it.
It was designed to dissipate energy from cell at 4V per cell. Not 4.2V but 4V since this way i am assured of longer cell life and from 4V to 4.2V it is like 30minutes of charging. During that time even the dummest charger starts to go to CV.
I used TL431 reference diodes to trigger PNP/NPN pair. NPN transistor is actually NFET capable of 5A continuous drain. However i noticed even 1A in closed space can be a fire hazard. So i use 0.5A drain. It works in my car for 4 years now. No events
Also i designed a LV alert into each module. I used Microchip TC54 voltage trigger to signal EMPTY at 3V per cell. While there is some power still in the cell at 3V it can drop to 2.5V in under a minute! I use optocooupler PC817 to signal events for a single cell. Currently i have this alarm set so it lights red LED on my dash. But i could just as easily connect BMS pin of Rev 2 inverter to put the car in "turtle mode".
There is also provision to use HV alert when a single cell reaches 4V BMS loop can slow the charger to 1A so that all cells align.
I tried to eliminate PNP transistor, but i found out its base hysteresis keeps TL431 from turning on too fast. This was designed explicidely to work with LiPo cells. It is a rather crude system with low parts count, but it is also EMI proof and reliable. I made 8S boards because i use cells in packs of 8.
You are free to use this system and further develop it if you like.
- LiPo_8Cell analog.zip
- (38.52 KiB) Downloaded 265 times
- LiPo_1Cell analog.zip
- (685.61 KiB) Downloaded 236 times
doobedoobedo
doobedoobedo
Re: Tough BMS
Ah OK
$ file LiPo_1Cell\ analog.pcb
LiPo_1Cell analog.pcb: Composite Document File V2 Document, Little Endian, Os: Windows, Version 5.1, Code page: 1252, Revision Number: 128, Total Editing Time: 1d+08:43:51, Last Saved Time/Date: Thu Aug 1 12:24:52 2019, Create Time/Date: Thu Feb 12 11:07:50 2015, Name of Creating Application: DesignSpark-
- Been thanked: 1138 times
Re: Tough BMS
OK untill this time i was looking for a complete schematic on my PC, but the only thing i found was my hand drawing when i was experimenting with LiPo cells.
I will post this for now so you can start experimenting. Later however i will try to make a propper schematic to put into DS.
This schematic i s only for the sensing part of BMS. I used R1 and R2 as symbols. It is really 3 resistors in series that allow for fine tuning of turn on point of 4.03V per cell.
R1 = 2K7 + 1K + 10K
R2 = 22K
NPN is MJD122
PNP is BC516
I didnt use LED between transistors since i figured PNP base has enough hysteresis. I only used R3 470R to reduce PNP and TL line current.
I will draw a complete schematic for you when i am able to focus on on the design
A
Shema za BMS.pdf- (280.75 KiB) Downloaded 349 times
Re: Tough BMS
Sorry, missed that post...
Here are 8S modules of this BMS. Each module is connected through opto to others and is active high. So if a cell passes 3V LED on my dash will lit and i will have to slow down and find an AC source...
Later on i experimentally connected top balancing connection to reduce the charging. Also i will have to redesign opto signalling to active low. It will be more failsafe that way.
Re: Tough BMS
Hi
I revisited my design and i am wondering how to simplify manufacture and signals.
Does anyone know a good signal opto chip for 8, 12 or 16 signals? Of course this would be smd chip.
Or i will just use 4x SFH6916 chip...
