VW eGolf hardware
- Has thanked: 134 times
- Been thanked: 342 times
VW eGolf hardware
Hi all. This weekend i borrowed eGolf 2019. Mainly because i wanted to find out if i can connect to CAN bus and record msg.
I found out it uses very nice liquid cooled and small charger. It can produce 7.2kW, but it is not single phase. It actually uses 2 phase charging. I checked with my clamp meter... 14A per phase. This is very good for European housing where 3phase is common. This leaves a remaining phase for house consumption.
VW eGolf charger 5QE915681B or N
Also i found a lot of other VW hardware is available online:
VW Passat inverter 3G0907070B
VW Golf inverter 5G0907070H
VW eGolf inverter 5QE907070
VW Golf hybrid charger 5QE915682K
Did anyone consider getting VW parts? Can we get to the CAN IDs?
Re: VW eGolf hardware
Yes, I was thinking about VW oem charger, you can get 5QE915682K less then 100eur. But I didn't find any useful information on the net and my CAN hacking skills are inefficient to tun it by myself.
- clanger9
Very interesting little unit. Are there any specs for 5QE915682K? It's from a hybrid, so presumably limited to 3.6kW?
Hello openinverter-enthusiasts,
I have the eGolf Inverter on my workbench
I’m still in a very early test-phase together with a
Bosch SMG-180.
So what’s inside the Inverter ?
etc.
I’ve made some pictures.
Regards
Michael
Bosch SMG-180.
etc.
Regards
Michael
- Has thanked: 211 times
- Been thanked: 588 times
I did some reverse engineering of this inverter. Did not get beyond designing a adaptor board, with some clearance issues to a johannes V3 board.
I had just a few signals left to sus out, had control over each of the IGBT sides.
All info on github : https://github.com/tomdebree/VW-GTE-Inverter
Nicely done Tom. I will look up your design.tom91 wrote: ↑Fri Mar 20, 2020 1:04 pm I did some reverse engineering of this inverter. Did not get beyond designing a adaptor board, with some clearance issues to a johannes V3 board.
I noticed several sets of GTE controler and controlers for EGolf for good price and they look very much the same.
Since i know Ampera uses 115kW motor and it has 15mm2 phase cables, EGolf and GTE use 25mm2 for 85kW motor. So inverter despite its small size has to be very similar for both.
And DCDC inside is a bonus too.
Which of the signals you didnt use yet? I may try to find them out.
I could use your mapping to design inverter with Lebowski brain. It uses 3x current sensors for FOC. Voltage isnt an issue there, also temperature sensing. Fault pin would simply be wired to reset.
How are the IGBTs triggered there? You need a low signal or high?
Also chip clearance wouldnt be an issue with Lebowski.
And of course Bas just put his code online as full open source!
Do You knows maybe in which cars Bosch SMG-180 motor was assembled? In e-Golf I saw it was, but elsewhere?
I found that VW chargers 5QE915682K are really cheap, so maybe also I will buy this and put on shelf
Maybe in future someone smarter will know how to use this.
Luckily some clever guy took good notes.arber333 wrote: ↑Fri Mar 20, 2020 5:50 pmWhich of the signals you didnt use yet? I may try to find them out.
Currently the Isolated feedbacks and temperatures are unknown and the current ratios, but all pins for the current sensors identified.
Kudos to you Tom!
So i will let the hot water in and measure the resistance then... the same way i did for Ampera inverter before John Kelly sent me IGBT datasheet.Currently the Isolated feedbacks and temperatures are unknown and the current ratios, but all pins for the current sensors identified.
I couldnt find the NTC beta in the datasheet for MH6560C.
- muehlpower
- Has thanked: 14 times
- Been thanked: 142 times
I have an air conditioning compressor from a Passat GTE. That should be the same as in E_Golf and Golf GTE. It is available from € 100 and is controlled by a LIN bus. So far I haven't been able to figure out what to send. The boudrate is 19600. Does someone have a car where to read the signal?
Hi again!
I manage to get one VW inverter here. Its so small!
I managed to open it up and i see the brain board gets its signals from the big connector on the side. So your idea was to replace its brain with your own master board. I would ask three questions, though i dont mean to imply the fairytale...
First question Tom91; why does it need isolated power supply?
Next question; Is there only one isolated supply or more required?
Third question; did you figure also the pinout on how to start the DCDC 12V converter? Any info on its connector pins? I see it is also ERNI 1.27mm 8P connector no. 284699.
So my plan is to build my interface board and try to use gen2 controler to drive a motor first with 60Vdc. Then i will try to make DCDC obey.
A
That inverter looks different then the one i had.arber333 wrote: ↑Wed Apr 15, 2020 5:57 pm I manage to get one VW inverter here. Its so small!
No it does not, it is the supply to the optos and isolators. Check the schematics.
No isolated supply, just 5V as far as i know and then a supply in of 20V (atleast that worked for me.
It is painful to get working right i remember that much. It takes 12-20V then creates the isolated supply from that.
No idea on the DCDC.
I would say there is quite some figuring out left to do, I should have disassembled the whole inverter and powered it on to try and intercept the signals to the power stages to check my findings.
I think i will do the same and trace the outputs vs your results. Hopefully they used the same layout.
I have here 50Vdc battery and also one 10A power supply that can supply enough current to turn my small ACIM motor.
It seems that it would be better to abandon the side connector and make a new cover from the front in which to mount a new board. Space is tight...
Do you have some photos of that inverter board? Maybe i can catch some similarities.
VW GTE test setup, dont mind the mumbling idioot.
So to get the isolation side to work you need to generate a 12-20V supply and then a pwm signal to start generating some voltage. there is a feedback output to indicate the isolated side has power.
Pictures of the brick i have and done the testing on, now its just down to getting it working really. Designed the PCB so I can use the Johannes brain to drive the IGBTS while the other signals and unkowns are on the screw terminals.
Dug out my setup, need to do more testing and documentation as now I do not know how to get the correct voltage on the isolated side and igbts switching.
Hope to get some done in the coming days.
Anyone has any info on VW inverter and charger wiring from Golf GTE? HV and LV connector pinout would be appreciated.
I have them sitting here not doing their thing and that frustrates me
- Been thanked: 11 times
Wicked! Thanks. I will try it from here then. Should be getting some CAN msg from charger.
I just picked up one of these inverters.
I think (on a Google image search based hunch) that it could be the same as the PIM in a fiat 500e.
I'm interested in a few things to do with that car in particular:
1) I'd love to add some sort of DC fast charge to it, so one option might be to tap into the connections for the battery at the inverter.
2) if the inverter in the fiat dies, or reports an issue, the fiat equivalent part number is $5k, whereas these inverters can be found much more cheaply than that. It'd be great to know if the only change required would be software
3) general interest, and a pipe dream of adding rear wheel drive to my 500e to make a 4wd beast.
Loving the resources posted so far. Thanks all who've submitted info.
- Has thanked: 83 times
- Been thanked: 429 times
DomT177 has taken logs from a GTE https://github.com/DomT177/GolfGTE might be useful with the egolf bits.
Currently trying to trick my GTE battery into thinking its on charge to discover the balance command.
How much of the DBC is known? Can you capture some internal canbus for me?Bigpie wrote: ↑Sun Feb 20, 2022 7:00 pm DomT177 has taken logs from a GTE https://github.com/DomT177/GolfGTE might be useful with the egolf bits.
I would suggest just putting charge into the pack to push the cells to near full and observe the canbus.
