Any driveability quirks/complaints?
Has thanked: 134 times
Been thanked: 342 times
Re: Any driveability quirks/complaints?
johu wrote: Sat May 01, 2021 7:55 am Been asked for many times. I suggest someone with a Toyota inverter tries it first :D
Maybe I can try to keep the basic slip calculation and just replace V/f by FOC? Hmm.
I volunteer my Mazda for testbed 😇.
I use gen2 boards modified for Volt inverter. I have Lacrosse ACIM motor here with resolver. I also have straight gen2 inverter in Mazda and it works with AB encoder. So i am able to test both versions. Also if you insist i can make Mazda work with single channel encoder.
jon volk
Post by jon volk »
Took the car out for a thrashing this morning with the recent upload and did not experience any elastic throttle feel. I could push hard on the regen into a corner and power out with no transition delay.
Has thanked: 12 times
Been thanked: 353 times
I have a gen 3 prius inverter and Siemens 1pv5135 in the E39 so happy to test foc. Mr.Toyota won't let anyting silly happen...
Boxster EV
Has thanked: 57 times
Been thanked: 49 times
Post by Boxster EV »
jon volk wrote: Sat May 01, 2021 12:10 pm Took the car out for a thrashing this morning with the recent upload and did not experience any elastic throttle feel. I could push hard on the regen into a corner and power out with no transition delay.
Just tried it - Elastic has gone - Fantastic.
The Panzer is now running the latest VolkSoft(tm) firmware. About to head out out on a voyage...
Has thanked: 383 times
Been thanked: 1589 times
I've tried adding the Volk mods to the latest software, can somebody test whether I succeeded?
Diff is here: https://github.com/jsphuebner/stm32-sin ... e6ac39730a
stm32_sine.bin
(47.46 KiB) Downloaded 342 times
johu wrote: Tue Aug 24, 2021 5:52 pm I've tried adding the Volk mods to the latest software, can somebody test whether I succeeded?
Hex please... i will just go around the block :twisted:
jon volk
Post by jon volk »
Let the personal injury claims begin.
Boxster EV
I’ll give this a try when back from holiday next week
Johu, can you post .hex file so i can load it to Mazda asap? Bin doesnt work for me. Tnx
Here you go.
stm32_sine.hex
(133.54 KiB) Downloaded 320 times
joromy
Post by joromy »
Is the Volk mods for tesla only, or can I use it on any acim?
jon volk
Post by jon volk »
Should be applicable to any acim motor as its just a modification of the fweak value at low throttle inputs. Theres a parameter added to adjust. If this function is not desired, then that value just gets set equal to fweak.
Well traction is very good and i am satisfied. But there seem to be no regen present. Not for throttle release or for brake signal. Even though i have it set to -60% in code. Is it possible you changed orientation of your math?
tnx
jon volk
Post by jon volk »
Maybe try bumping it up more? I noticed the higher fweak did reduce regen, but it was a matter of readjusting parameters for me.
Will check in code as well
jon volk
Post by jon volk »
Curious if there was any further feedback on Johu's integration. I have not tried that file since my own setup has been running flawlessly and Im terrified to change anything haha.
