wanted: 2nd gen leaf inverter in UK
- janosch
- Has thanked: 98 times
- Been thanked: 102 times
- Has thanked: 134 times
- Been thanked: 339 times
Re: wanted: 2nd gen leaf inverter in UK
- janosch
- janosch
It does say 2013, but I just browsed around a bit and it often says that Leafs are Diesel as well, so I wouldn't put money on the years being correct either
That site is a great resource though, they have a whole stack for 800 for example: https://rrr.lt/en/used-part/adv29260-29 ... issan+leaf
- SciroccoEV
- Been thanked: 15 times
It's a Gen1, no question. The cast top case with Nissan emblem gives it away.
Gen1 - no stack. Inverter is mounted on a subframe above the motor and connected via a short cable. HV box (inc DC/DC) is seperate and vertical behind motor/inverter. Charger is separate and at rear of vehicle.
Gen2 introduced the stack, Motor, Inverter, charger&DC/DC, HV box. Pressed steel top cover.
I have all three generations.
- janosch
