Inverter P/N Compatible with V1c Gen 3 board? (G9200-47230)
invokeperformance
Hello does anyone know if this 2014 Prius inverter P/N (G9200-47230) compatible with the V1c board it not listed on the WIKI under Toyota part numbers. I believe it is just want to confirm before buying. thanks
- ZooKeeper
- Has thanked: 8 times
- Been thanked: 5 times
Re: Inverter P/N Compatible with V1c Gen 3 board? (G9200-47230)
If I recall correctly, the important numbers are on the control board inside.
Time for ICE Melt
I have the same inverter and the v1d small board fits in nicely. Thus, I think that the v1c board is too big.
invokeperformance
thanks that's good information what year car is your inverter from?
2015invokeperformance wrote: ↑Wed Jun 30, 2021 6:01 pmthanks that's good information what year car is your inverter from?
- Has thanked: 91 times
- Been thanked: 517 times
Please update the wiki with details
I've seen this info in other threads as well. 2010-2011 use the "large" boards, everything Gen 3 after that uses the "small" boards originally for the Auris/Yaris. V1D (I believe) is specifically for dual motor where V1C is for single, and they're both available in small and large designs. Single motor will be a bit cheaper.
FWIW, the small board inverters seems a hair cheaper to buy used.
Patreon supporter and mild troublemaker. You can be both.
