How to charge HV batteries off car?
Hi, this is probably a newby question,. But what is the simplest way to charge HV automotive batteries up when they're not connected to the car?
I want to use my Lexus hybrid battery pack as a test battery to get things moving but I need to charge it up first,. And I guess I'll need to do the same once I have purchased my proper battery.
What is the recommended method?
(Please bear in mind I am not an electrical engineer so can't knock something up using a Prius inverter and some copper wire)
Dan
Dan
Re: How to charge HV batteries off car?
For a hybrid pack, especially Toyota/Lexus ones, my suggestion would be one module at a time while secured in their case.
Isaac96
As ZooKeeper said. You can either use a proper charger or just a simple lab power supply - those have both current and voltage control so they charge batteries safely, also they're generally useful for EV conversion work.
Yea, I know... so useful I am amassing a collection of them
- Has thanked: 145 times
- Been thanked: 369 times
See here is a hard core method, but it works for every kind of automotive battery you can imagineDan--T wrote: ↑Tue Jul 06, 2021 11:21 pm Hi, this is probably a newby question,. But what is the simplest way to charge HV automotive batteries up when they're not connected to the car?
Dan
https://leafdriveblog.wordpress.com/202 ... r-charger/
You can get a smaller version autotransformer for single phase connection and it will work up to 300Vdc or so.
If you dont need to have a fast charging then i recommend you buy a simple PSU for voltage you need to get battery to.
- rstevens81
- Has thanked: 29 times
- Been thanked: 114 times
If they are in simple modules you can charge each module by themselves with a cheap lion charger from China land (if you open them up you can change the charge point voltage)
I did this 12 at a time to 3.75volts (45v) to put my modules into a storage state. I also monitored the BMS to be extra safe.
Ok, I ideally didn't want to have to split open the battery pack but if that's the best/ only feasible way to do it I can.
So I think each lexus cell is 7.2v,. So I just need to buy a power supply capable of over 7.2v and do them all one at a time?
The modules are wired in series, the only way to do them all at once @ 7.2v is to turn every other one around so all the (-) & (+) terminals are on the same side.
RetroZero
- Has thanked: 624 times
- Been thanked: 64 times
What about the prius gen 2 Inverter as charger? There's a thread and quite some work done. Needs some fine tuning and testing from what I understand. I hope to get into that part pretty soon as I too have a hybrid pack that needs recharging. If I understand correctly, if there is no bms, current and voltage has to be real low as the weakest modules are going to take most of the first phase of charging.
- marcexec
- Has thanked: 888 times
- Been thanked: 91 times
If you have to buy, I can recommend Meanwell LED power supplies. They come in various voltages and power levels and are current and voltage adjustable. I run a pair of waterproof HLGs to charge my bike overnight without issues (after switching to waterproof...).
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
I think you could use a bunch of LED power supplies connected in series for this job.
Dan-t,
Where you successful in using the battery pack on the bench?
I am looking to do the same.
I have one Chevy Volt pack on the floor for my HV test source. It works great for years now. I also use one Mitsu Outlander OBC/DCDC. However i need to be careful here as i dont have liquid cooling connected. I only have water in charger and hose looped between ports to have some thermal mass.
I charge slow at some 3A => 1kW.
3PH autotransformer setup i use as quick charger in case if all my chargers would somehow fail or i would really need to charge quickly....
Can you share how you connect to the hv battery and any documentation on how you (if you do) control the BMS?
Its rather complicated.
I used simpBMS connected to Ampera OEM BMS. It was not much, only CAN lines and power supply. But in the end i removed simpBMS in favour of Hanzor BMS because i could read 12S packs via Bluetooth and for SimpBMS i would have to have serial connected.
Generaly i made simple connections from cell tabs to screw terminals. From there i can use whatever connectors and BMS i like.
Lately i experimented a lot with ZEVA BMS...
viewtopic.php?p=78097#p78097
Last week i made changes in my workshop and now i will use Volt gen2 battery. Probably i will use ZEVA BMS. If you like i can post my assembly here.
