Variable throttle response
Greenbeast
Post by Greenbeast »
Forgive me if this is common knowledge in the leaf motor reuse world but it occurred to me that a variable response throttle might be handy given I am converting a 4x4, I am keeping the transmission and therefore the stock low range box.
But presumably with low end torque of an electric motor I don't really need the low range gears I just need a way to make the throttle less responsive?
Make sense?
Tremelune
Been thanked: 13 times
Re: Variable throttle response
Post by Tremelune »
At least with the Thunderstruck VCU, you can configure the throttle response curve. For example, you could have the first half of the pedal travel provide maybe 20% of the available torque, and then have the last half ramp up to full torque. This would give you fine control for crawling while still allowing full power. You can set a few points on the throttle curve to tune to your goals.
Has thanked: 246 times
Been thanked: 469 times
if you use a drop in openinverter board, you can map the throttle in the web interface
