Needed: Prius Gen3 inverter
- Been thanked: 1918 times
Anyone have an unused Prius inverter they'd like to sell? Hoping to get it faster than via ebay.
- Has thanked: 166 times
- Been thanked: 413 times
Re: Needed: Prius Gen3 inverter
I have used Auris inverter dissassembled to fit control board on it. It is in working condition but currently i dont currently have time to mess with it...
I also have Yaris inverter which i cant use for charging since its main cap is not rated high enough for comfort.
I took off their OEM control boards and i currently sport some openinverter control board.
mario
- Has thanked: 117 times
- Been thanked: 24 times
Johanes,
Try here:
https://allegro.pl/listing?string=PRZET ... RIUS%20III
You can find it for reasonable price - around 500 zl=<100€ and shipping is fast.
I received it in 3 days in Croatia. Shipping is around 200 zl.
Great, might come back to either of this! Swapping the power stage should be sufficient.
But for now I'll try something else: wired the inductor to phase 2 of MG2 so I can just use boost mode charging on the STM32.
Experiment failed. Since the converter is on the same DC bus as the inverters, the entire bus is shorted. Also the DC/DC converter is no longer working for some reason. So will have to replace the whole unit.
Nobody on allegro.pl ships to Germany
mario
That is strange... I would expect that they don't ship to Croatia but do to Germany.
Ask seller directly and you should be good.
Found many inverters here: https://rrr.lt/de/gebrauchte_ersatzteil ... r-inverter
Ordered one for 140€ delivered
- rstevens81
- Has thanked: 29 times
- Been thanked: 114 times
Fyi the top from a Prius fits into a Yaris inverter, just sent/sold cheap my spare (Yaris inverter) to bigpie
