Toyota RAV4 Inverter Hacking
Been thanked: 1139 times
Picked up a 2016 Rav4 inverter on ebay for a very good price (100gbp shipped). This guy has 3 inverters, boost converter and dcdc converter. First look inside seems very similar to the is300h inverter.
johnspark
Has thanked: 59 times
Been thanked: 48 times
Re: Toyota RAV4 Inverter Hacking
Post by johnspark »
Very interesting...
jnsaff
Been thanked: 8 times
Post by jnsaff »
I also picked up one of these and also a Gen3 + Gen4 Prius inverters. Will be very interesting to try and make sense of these. Will probably start with the live hacking session recordings as a follow along.
jap
Post by jap »
Any further info on these? Can you use any existing board to run one of MG outputs or is there something special going on?
Edit: I suppose this is the same deal as with RX450 inverter?
viewtopic.php?f=14&t=757
hombre77
Post by hombre77 »
What is the status of the reversed engineering? I am planning to use NX300h inverter which as far as I know uses the same comms as RX and probably as 3 motors RAV4. Does anyone has logs from vehicle with 3 motors inverters?
