Are our motors compatible
ChironWSC
Post by ChironWSC »
Hi
Trying to find out if any of the Toyota inverters would work with the motors we are using on various projects.
We are using axial flux synchronous three phase BLDC electric motors. The motors need controllers with sinusoidal signal and high switching frequency.
Re: Are our motors compatible
Yes, sounds compatible. What is“high“switching frequency? Toyota inverters pretty much max out at 8.8 kHz
Been thanked: 413 times
ChironWSC wrote: Wed Sep 15, 2021 11:25 am Hi
You mean 20 pole EMRAX motors? They would need at least 16kHz to propperly describe 800Hz sinus they need...
I have managed to run such motor at 360Vdc with Volt inverter and Lebowski at 6kHz and it was terribly loud. At 16kHz though it was only annoying. I would think optimal function with theese would be 18kHz. Video is in Slovenian as i made it to prove Roman i can run his motor just fine :).
ChironWSC
Post by ChironWSC »
Yes the same Emrax Motors. We would be using the 228 and 208 motors.
So looks like the Toyota inverter is not really suitable?
Thanks Henry
arber333 wrote: Thu Sep 16, 2021 7:30 pm
