Since summer 2020 I have been building on my Volkswagen Golf 3, which in fact is a original CitySTROMer. The first posts of this topic are gonna be a quick recap of the last 13 months. I've been updating on a Dutch Volkswagen forum since I bought the car, where you can see a lot of additional pictures.
http://www.volksforum.com/forum/showthr ... ge=1&pp=20
I bought the car along with its original 20kW motor, but without battery's. The original motor with Siemens inverter was functioning, until I needed to go to the RDW (Dutch vehicle authority) to import the car. At that moment the inverter stopped functioning and we needed to get a trailer.
After I was finished importing the car, I could finally start dismantling it.
This was the new motor, which I wanted to put in the Golf at the time. It was going to be driven by 2 Sevcon's Size6, and an original 02A (Diesel) gearbox.
The Golf was then upgraded with a much better VR6 drivetrain to cope with the weight and power.
We made a custom adaptor plate for the motor.
And then we put on a taperlock with tapped holes to fit on the flywheel.
Work on the batterypack started.
It was build using 1792 VTC6 18650 cells. There were paralleled 28 blocks of 64 cells, which gave it a nominal voltage of 103.6 volts. It had a capacity of about 19.4kWh.
The chargers were fitted.
Fitting the 2 Sevcon controllers to the custom made cooling plate.
Here came the first testdrive, which was in January this year.
Charging the car with 76A DC, 8.3kW.
At this point, the car was more or less finished. I was a little disappointed by the poor range (140 kilometer), the dissapointing performance (90kW) and the charging speed could have been better.
I decided I had learned a lot by doing this conversion, and I now knew what I had to do in a next build...
